I was wondering if it’s possible to power this board through the type-c 3.0 port leaving the OTG port available for other purposes?
No, don’t try this.
You can power this device by GPIO pin to free the OTG USB port.
In that case, are there any UPS battery HATs you could recommend for the Zero? I was looking at some for the Raspberry Pi Zero but those require Pogo pins which I don’t think the Radxa Zero has. I was hoping to use a Zero without headers but if GPIO is the only way I can make that compromise if necessary.
