I want to mount TI DLPDLCR2000EVM on ROCK Pi 4 to use as small projector because ROCK Pi 4 has more cores than Raspberry pi4.
https://www.ti.com/tool/DLPDLCR2000EVM
I have already been able to realize a small projector with TI DLPDLCR2000EVM on raspberry pi4.
Can the ROCK Pi4 support DPI (Parallel Display Interface) to output RGB 24 bit (RGB888) via GPIO as well as the Raspberry Pi4?
When outputting with RGB888, is the output pin layout on the GPIO also the same as the Raspberry Pi4?
No. ROCK Pi 4 can not output RGB888 from the GPIO.
Thank you for your prompt reply.
