Can radxa zero can boot from 2nd partition from SD card? if it can how to make it? Thanks
it only work when I put boot script in the 1st partition. if I put uboot boot script at 2nd partition. it can’t bootup. Do you have any way to let the boot script work when I put in 2nd partition?
You have to tell U-Boot to look for the boot script there. Maybe this is helpful depending on your distro? https://forum.armbian.com/topic/12205-u-boot-question-boot-2nd-partition/
You may have to recompile U-Boot with the desired bootcmd string: https://wiki.radxa.com/Zero/dev/u-boot
weird, when I put boot.scr at 1st fat partition it can success bootup, but when I put boot.scr at 2nd fat partition it failed.
Success:
U-Boot 2021.07-gdb6738fe-dirty (Sep 18 2022 - 12:18:39 -0700) radxa-zero
Model: Radxa Zero
SoC: Amlogic Meson G12A (S905Y2) Revision 28:b (30:2)
DRAM: 1 GiB
MMC: sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
Loading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Net: Net Initialization Skipped
No ethernet found.
starting USB…
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found U-Boot script /boot.scr
968 bytes read in 5 ms (188.5 KiB/s)
Executing script at 08000000
fatload mmc 1:2 0x08008000 /meson-g12a-radxa-zero.dtb
74404 bytes read in 9 ms (7.9 MiB/s)
ext4load mmc 1:3 0x13000000 vmlinuz
10297704 bytes read in 911 ms (10.8 MiB/s)
unzip 0x13000000 0x08080000
Uncompressed size: 24904192 = 0x17C0200
ext4load mmc 1:3 0x13000000 initrd
24517204 bytes read in 2161 ms (10.8 MiB/s)
booti 0x08080000 0x13000000:1761a54 0x08008000
Moving Image from 0x8080000 to 0x8200000, end=9a60000
Flattened Device Tree blob at 08008000
Booting using the fdt blob at 0x8008000
Loading Ramdisk to 3a7db000, end 3bf3ca54 … OK
Loading Device Tree to 000000003a7c5000, end 000000003a7da2a3 … OK
Starting kernel …
Failed:
Model: Radxa Zero
DRAM: 1 GiB
In: serial
Out: serial
Err: serial
No ethernet found.
starting USB…
USB XHCI 1.10
Scanning mmc 1:1…
Scanning disk sd@ffe03000.blk…
Disk sd@ffe03000.blk not ready
Scanning disk sd@ffe05000.blk…
Scanning disk mmc@ffe07000.blk…
Disk mmc@ffe07000.blk not ready
Found 4 disks
** Unable to read file ubootefi.var **
Failed to load EFI variables
BootOrder not defined
EFI boot manager: Cannot load any image
Scanning mmc 1:2…
968 bytes read in 3 ms (314.5 KiB/s)
74404 bytes read in 10 ms (7.1 MiB/s)
10297704 bytes read in 912 ms (10.8 MiB/s)
24517204 bytes read in 2160 ms (10.8 MiB/s)
“Synchronous Abort” handler, esr 0x96000004
elr: 000000000105f628 lr : 000000000104f658 (reloc)
elr: 000000003dfb3628 lr : 000000003dfa3658
x0 : 252cf00104280c01 x1 : 000000003dfb9f40
x2 : 0000000000000010 x3 : 0000000000000000
x4 : 0000000000000000 x5 : 252cf00104280c01
x6 : 000000003bf74a40 x7 : 0000000000000007
x8 : 0000000000000000 x9 : 0000000000000008
x10: 000000000000bc60 x11: 000000003bf3e2ac
x12: 000000000000ba38 x13: 000000003bf3e268
x14: 000000003a7c5000 x15: 0000000000000020
x16: 000000003df80108 x17: 000000003bf78400
x18: 000000003bf51dd0 x19: 000000003af3f040
x20: 000000003df54fc8 x21: 000000003dfb9f40
x22: 0000000000000300 x23: 000000003bf61af0
x24: 000000003dfd9300 x25: 0000000005300000
x26: 0000000000300000 x27: 0000000000000000
x28: 0000000000000300 x29: 000000003bf3e270
Code: eb02009f 54000061 52800000 14000006 (386468a3)
Resetting CPU …
resetting …
the boot script like follow:
setenv bootargs ‘xxxxxxxxxxxxx’
load fdt
fatload mmc 1:2 ${fdt_addr_r} ${fdtfile}
load kernel
ext4load mmc 1:3 ${ramdisk_addr_r} vmlinuz
unzip ${ramdisk_addr_r} ${kernel_addr_r}
load initrd
ext4load mmc 1:3 ${ramdisk_addr_r} initrd
boot
booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}
hi @theophile
I compare the u-boot build follow wifi page and the one download form https://dl.radxa.com/zero/images/loader/u-boot.bin
wiki: U-Boot 2021.07-gdb6738fe (Dec 24 2022 - 08:47:38 -0800) radxa-zero,
download: U-Boot 2022.04-00001-g4bbaa9c0 (Jun 29 2022 - 15:17:30 +0800) radxa-zero
and seem the downloaded u-boot fixed the issue: can’t boot when u-boot script are location at 2nd partition.
So can you help me how to get the latest u-boot source or the build of 2022.04-00001-g4bbaa9c0 , Thanks a lot and Merry Christmas!
when I download u-boot from https://dl.radxa.com/zero/images/loader/ it works. so can you let me know what is the branch of uboot in https://dl.radxa.com/zero/images/loader/ ?
Hi Theophile, can you tell me how the u-boot build out as the one in https://dl.radxa.com/zero/images/loader/u-boot.bin. I following the wiki page https://wiki.radxa.com/Zero/dev/u-boot but seem the binary are different size
