Can not load rootfs on rockpin10
Hi
I follow https://wiki.radxa.com/RockpiN10/dev/Debian to build a image, system hung and kernel can not load rootfs.
Compare to good log, bellow message is missed. My kernel version is Linux version 4.4.167-gd6ee13d61c6d. The good version from offical image is Linux version 4.4.167-14-rockchip-g53bdb2fa44e8. Can anyone give me some advice?
[ 4.137343] mmc2: MAN_BKOPS_EN bit is not set
[ 4.145847] rk817-codec rk817-codec: rk817_platform_probe() parse device tree property error -19
[ 4.149890] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 4.150890] mmcblk2: mmc2:0001 D9D16G 14.5 GiB
[ 4.151541] mmcblk2boot0: mmc2:0001 D9D16G partition 1 4.00 MiB
[ 4.152209] mmcblk2boot1: mmc2:0001 D9D16G partition 2 4.00 MiB
[ 4.152845] mmcblk2rpmb: mmc2:0001 D9D16G partition 3 4.00 MiB
[ 4.161591] mmcblk2: p1 p2
[ 4.194312] u32 classifier
[ 4.203280] Netfilter messag
Would you please show more boot log provided by tool dmesg?
I mounted the boot.img to a folder, and can find files bellow:
gang@deep:~/radxa_github/rockchip-bsp/out/mnt$ tree
├── extlinux
│ └── extlinux.conf
├── Image
└── rk3399pro-rockpi-n10-linux.dtb
I have dd out boot.img from radxa offical image rockpin10bc_debian_buster_xfce4_arm64_20200710_0335-gpt.img, files are much more than what I build out:
gang@deep:~/radxa_github/rockchip-bsp/out/mnt2$ tree
├── boot.cmd
├── boot.scr
├── config-4.4.167-14-rockchip-g53bdb2fa44e8
├── dtbs
│ └── 4.4.167-14-rockchip-g53bdb2fa44e8
│ └── rockchip
│ ├── overlay
│ │ ├── README.rockchip-overlays
│ │ ├── rk3399pro-console-on-uart2.dtbo
│ │ ├── rk3399pro-console-on-uart4.dtbo
│ └── rk3399-vr-android.dtb
├── extlinux
│ └── extlinux.conf
├── initrd.img-4.4.167-14-rockchip-g53bdb2fa44e8
├── System.map-4.4.167-14-rockchip-g53bdb2fa44e8
├── uEnv.txt
├── uEnv.txt.bak
└── vmlinuz-4.4.167-14-rockchip-g53bdb2fa44e8
Since there’s bytes limitation when post log, I split the log into 2 parts.
DDR Version 1.20 20190314
In
Channel 0: LPDDR3, 800MHz
CS = 0
MR0=0xD8
MR1=0xD8
MR2=0xD8
MR3=0xD8
MR4=0x3
MR5=0x6
MR6=0x4
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0xD8
MR1=0xD8
MR2=0xD8
MR3=0xD8
MR4=0x3
MR5=0x6
MR6=0x4
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=2048MB
Channel 1: LPDDR3, 800MHz
CS = 0
MR0=0xD8
MR1=0xD8
MR2=0xD8
MR3=0xD8
MR4=0x3
MR5=0x6
MR6=0x4
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
CS = 1
MR0=0xD8
MR1=0xD8
MR2=0xD8
MR3=0xD8
MR4=0x3
MR5=0x6
MR6=0x4
MR7=0x0
MR8=0x1F
MR9=0x1F
MR10=0x1F
MR11=0x1F
MR12=0x1F
MR13=0x1F
MR14=0x1F
MR15=0x1F
MR16=0x1F
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA0DAA0, stride = 0xD
OUT
Boot1: 2018-08-06, version: 1.15
CPUId = 0x0
ChipType = 0x10, 217
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=14800MB
FwPartOffset=2000 , 100000
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 67406
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
GPT part: 0, name: boot, start:0x8000, size:0x100000
GPT part: 1, name: rootfs, start:0x108000, size:0xbb87df
no find partition:uboot.
LoadTrust Addr:0x4000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xd0480
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):cd61876
NOTICE: BL31: Built : 16:25:54, Jan 23 2019
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-00018-ge41695afe3 (Apr 08 2021 - 13:24:56 +0800)
Model: Radxa ROCK Pi N10
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bf5000
Sysmem: init
Using default environment
dwmmc@fe320000: 1, sdhci@fe330000: 0
Error: “rkimg_bootdev” not defined
Bootdev: mmc 1
MMC: no card present
mmc_init: -123, time 0
rockchip_get_bootdev: can’t find dev_desc!
init_resource_list: dev_desc is NULL!
DTB: rk-kernel.dtb
bad resource image magic:
init_kernel_dtb dtb in resource read fail
Can’t find UCLASS_IO_DOMAIN driver -19
[Vendor ERROR]:Invalid boot device type(0)
rockchip_set_serialno: could not find efuse device
rockchip_get_boot_mode: dev_desc is NULL!
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 24000 KHz, init 24000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 24000 KHz
dpll 800000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
Hit key to stop autoboot(‘CTRL+C’): 0
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1…
Found /extlinux/extlinux.conf
pxefile_addr_str = 0x00500000
bootfile = /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
reading /extlinux/extlinux.conf
277 bytes read in 9 ms (29.3 KiB/s)
1: kernel-4.4
Retrieving file: /Image
reading /Image
20240392 bytes read in 109 ms (177.1 MiB/s)
append: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=UUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE rootfstype=ext4 init=/sbin/it
Retrieving file: /rk3399pro-rockpi-n10-linux.dtb
reading /rk3399pro-rockpi-n10-linux.dtb
100920 bytes read in 9 ms (10.7 MiB/s)
Flattened Device Tree blob at 08300000
Booting using the fdt blob at 0x8300000
‘reserved-memory’ region@110000: addr=110000 size=f0000
Loading Device Tree to 00000000e9dca000, end 00000000e9de5a37 … OK
Adding bank: 0x00200000 - 0xf8000000 (size: 0xf7e00000)
Total: 1781.846 ms
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.167-gd6ee13d61c6d (gang@deep) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.051
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@00000000': base 0x0000000000000000, size 0 MiB
[    0.000000] cma: Reserved 256 MiB at 0x00000000d9c00000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7ed0000 s46120 r8192 d31704 u86016
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 999432
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb=1 coherent_pool=1m earlyprintk console=ttyS2,1500000n8 rw root=UUID=B921B045-1DF0-41C3-AF44-4C6F280D3FAE t
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf7e87000-0xf7ec7000] (0MB) mapped at [ffffffc0f7e87000-ffffffc0f7ec6fff]
[    0.000000] Memory: 3703844K/4061184K available (12542K kernel code, 1590K rwdata, 4432K rodata, 1152K init, 2076K bss, 95196K reserved, 262144K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 GB)
[    0.000000]       .init : 0xffffff8009120000 - 0xffffff8009240000   (  1152 KB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008cc0000   ( 12544 KB)
[    0.000000]     .rodata : 0xffffff8008cc0000 - 0xffffff8009120000   (  4480 KB)
[    0.000000]       .data : 0xffffff8009240000 - 0xffffff80093cd808   (  1591 KB)
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 GB maximum)
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 MB actual)
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 KB)
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 MB)
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @f3100000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000000f3090000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000f30a0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frac as parent of dclk_vop0, rate changes may not work
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frac as parent of dclk_vop1, rate changes may not work
[    0.000000] rockchip_cpuclk_pre_rate_change: limiting alt-divider 33 to 31
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.002246] Console: colour dummy device 80x25
[    0.002690] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.003668] pid_max: default: 32768 minimum: 301
[    0.004222] Security Framework initialized
[    0.004617] Yama: becoming mindful.
[    0.004968] AppArmor: AppArmor disabled by boot time parameter
[    0.005570] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.006227] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.007672] Initializing cgroup subsys memory
[    0.008111] Initializing cgroup subsys devices
[    0.008543] Initializing cgroup subsys freezer
[    0.008977] Initializing cgroup subsys net_cls
[    0.009408] Initializing cgroup subsys perf_event
[    0.009862] Initializing cgroup subsys net_prio
[    0.010316] Initializing cgroup subsys hugetlb
[    0.010748] Initializing cgroup subsys pids
[    0.011182] ftrace: allocating 44481 entries in 174 pages
[    0.130578] sched-energy: Sched-energy-costs installed from DT
[    0.131144] CPU0: update cpu_capacity 401
[    0.131577] ASID allocator initialised with 32768 entries
[    0.135235] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.136621] Platform MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
[    0.138891] Detected VIPT I-cache on CPU1
[    0.138924] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.138954] CPU1: using LPI pending table @0x00000000f3340000
[    0.139001] CPU1: update cpu_capacity 401
[    0.139005] CPU1: Booted secondary processor [410fd034]
[    0.139544] Detected VIPT I-cache on CPU2
[    0.139564] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.139591] CPU2: using LPI pending table @0x00000000f3360000
[    0.139619] CPU2: update cpu_capacity 401
[    0.139622] CPU2: Booted secondary processor [410fd034]
[    0.140149] Detected VIPT I-cache on CPU3
[    0.140169] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.140196] CPU3: using LPI pending table @0x00000000f33c0000
[    0.140222] CPU3: update cpu_capacity 401
[    0.140226] CPU3: Booted secondary processor [410fd034]
[    0.140756] Detected PIPT I-cache on CPU4
[    0.140783] CPU4: found redistributor 100 region 0:0x00000000fef80000
[    0.140822] CPU4: using LPI pending table @0x00000000f33f0000
[    0.140860] CPU4: update cpu_capacity 1024
[    0.140864] CPU4: Booted secondary processor [410fd082]
[    0.141430] Detected PIPT I-cache on CPU5
[    0.141448] CPU5: found redistributor 101 region 0:0x00000000fefa0000
[    0.141484] CPU5: using LPI pending table @0x00000000f2830000
[    0.141511] CPU5: update cpu_capacity 1024
[    0.141514] CPU5: Booted secondary processor [410fd082]
[    0.141643] Brought up 6 CPUs
[    0.153941] SMP: Total of 6 processors activated.
[    0.154402] CPU features: detected feature: GIC system register CPU interface
[    0.155082] CPU features: detected feature: 32-bit EL0 Support
[    0.155642] CPU: All CPU(s) started at EL2
[    0.156071] alternatives: patching kernel code
[    0.157874] devtmpfs: initialized
[    0.175468] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.176388] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.182666] xor: measuring software checksum speed
[    0.222511]    8regs     :  2854.000 MB/sec
[    0.262573]    8regs_prefetch:  2560.000 MB/sec
[    0.302634]    32regs    :  3192.000 MB/sec
[    0.342696]    32regs_prefetch:  2844.000 MB/sec
[    0.343126] xor: using function: 32regs (3192.000 MB/sec)
[    0.343648] pinctrl core: initialized pinctrl subsystem
[    0.344953] NET: Registered protocol family 16
[    0.357811] cpuidle: using governor ladder
[    0.369833] cpuidle: using governor menu
[    0.370216] Registered FIQ tty driver
[    0.370789] vdso: 2 pages (1 code @ ffffff8008cc6000, 1 data @ ffffff8009244000)
[    0.371496] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.373197] DMA: preallocated 1024 KiB pool for atomic allocations
[    0.397262] console [pstore-1] enabled
[    0.397618] pstore: Registered ramoops as persistent store backend
[    0.398212] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[    0.503093] raid6: int64x1  gen()   474 MB/s
[    0.571111] raid6: int64x1  xor()   420 MB/s
[    0.639250] raid6: int64x2  gen()   656 MB/s
[    0.707298] raid6: int64x2  xor()   596 MB/s
[    0.775391] raid6: int64x4  gen()   927 MB/s
[    0.843507] raid6: int64x4  xor()   666 MB/s
[    0.911634] raid6: int64x8  gen()   751 MB/s
[    0.979709] raid6: int64x8  xor()   627 MB/s
[    1.047814] raid6: neonx1   gen()   994 MB/s
[    1.115929] raid6: neonx1   xor()   674 MB/s
[    1.184026] raid6: neonx2   gen()  1323 MB/s
[    1.252136] raid6: neonx2   xor()   983 MB/s
[    1.320240] raid6: neonx4   gen()  1761 MB/s
[    1.388357] raid6: neonx4   xor()  1146 MB/s
[    1.456452] raid6: neonx8   gen()  1694 MB/s
[    1.524562] raid6: neonx8   xor()  1250 MB/s
[    1.524959] raid6: using algorithm neonx4 gen() 1761 MB/s
[    1.525461] raid6: .... xor() 1146 MB/s, rmw enabled
[    1.525918] raid6: using intx1 recovery algorithm
[    1.528415] rockchip-pinctrl pinctrl: unsupported driver strength 10
[    1.529009] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 153
[    1.529649] reg-fixed-voltage host-5v: Error applying setting, reverse things back
[    1.530500] host_5v: supplied by vcc5v0_usb
[    1.531171] rockchip-pinctrl pinctrl: unsupported driver strength 10
[    1.531776] rockchip-pinctrl pinctrl: pin_config_set op failed for pin 154
[    1.532413] reg-fixed-voltage vbus-typec: Error applying setting, reverse things back
[    1.533275] vbus_typec: supplied by vcc5v0_usb
[    1.534819] iommu: Adding device ff650000.vpu_service to group 0
[    1.535456] iommu: Adding device ff660000.rkvdec to group 1
[    1.536097] iommu: Adding device ff8f0000.vop to group 2
[    1.536678] iommu: Adding device ff900000.vop to group 3
[    1.537260] iommu: Adding device ff910000.rkisp1 to group 4
[    1.538250] rk_iommu ff650800.iommu: can't get sclk
[    1.538975] rk_iommu ff660480.iommu: can't get sclk
[    1.539641] rk_iommu ff8f3f00.iommu: can't get sclk
[    1.540280] rk_iommu ff903f00.iommu: can't get sclk
[    1.540906] rk_iommu ff914000.iommu: can't get sclk
[    1.541724] SCSI subsystem initialized
[    1.542248] usbcore: registered new interface driver usbfs
[    1.542796] usbcore: registered new interface driver hub
[    1.543364] usbcore: registered new device driver usb
[    1.543904] media: Linux media interface: v0.10
[    1.544375] Linux video capture interface: v2.00
[    1.544889] pps_core: LinuxPPS API ver. 1 registered
[    1.545356] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    1.546216] PTP clock support registered
[    1.547654] Advanced Linux Sound Architecture Driver Initialized.
[    1.548754] Bluetooth: Core ver 2.21
[    1.549113] NET: Registered protocol family 31
[    1.549522] Bluetooth: HCI device and connection manager initialized
[    1.550117] Bluetooth: HCI socket layer initialized
[    1.550577] Bluetooth: L2CAP socket layer initialized
[    1.551078] Bluetooth: SCO socket layer initialized
[    1.551889] NetLabel: Initializing
[    1.552210] NetLabel:  domain hash size = 128
[    1.552627] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.553120] NetLabel:  unlabeled traffic allowed by default
[    1.554366] clocksource: Switched to clocksource arch_sys_counter
[    1.614129] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[    1.615138] NET: Registered protocol family 2
[    1.615995] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[    1.616916] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    1.618345] TCP: Hash tables configured (established 32768 bind 32768)
[    1.619102] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    1.619822] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    1.620776] NET: Registered protocol family 1
[    1.622239] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[    1.623133] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    1.626933] audit: initializing netlink subsys (disabled)
[    1.627475] audit: type=2000 audit(1.548:1): initialized
[    1.628368] Initialise system trusted keyring
[    1.629156] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.636847] VFS: Disk quotas dquot_6.6.0
[    1.637371] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.639460] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.640535] fuse init (API version 7.23)
[    1.641595] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.648177] SGI XFS with ACLs, security attributes, realtime, no debug enabled
[    1.651114] Key type big_key registered
[    1.651516]
[    1.651516] TEE Core Framework initialization (ver 1:0.1)
[    1.652166] TEE armv7 Driver initialization
[    1.652994] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    1.653614] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    1.654402] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    1.659252] NET: Registered protocol family 38
[    1.659689] Key type asymmetric registered
[    1.660073] Asymmetric key parser 'x509' registered
[    1.660717] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    1.661411] io scheduler noop registered
[    1.661783] io scheduler deadline registered (default)
[    1.662426] io scheduler cfq registered
[    1.665679] phy phy-ff770000.syscon:[email protected]: Failed to get VBUS supply regulator
[    1.668072] rockchip-mipi-dphy-rx ff770000.syscon:mipi-dphy-rx0: invalid resource
[    1.672754] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found
[    1.673367] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    1.673988] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    1.674609] rockchip-pcie f8000000.pcie: missing "memory-region" property
[    1.675249] PCI host bridge /pcie@f8000000 ranges:
[    1.675716]   MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[    1.676202]    IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[    2.222431] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    2.223095] rockchip-pcie f8000000.pcie: deferred probe failed
[    2.223769] rockchip-pcie: probe of f8000000.pcie failed with error -110
[    2.225562] rk-vcodec ff650000.vpu_service: no regulator for vcodec
[    2.226521] rk-vcodec ff650000.vpu_service: probe device
[    2.227324] rk-vcodec ff650000.vpu_service: drm allocator with mmu enabled
[    2.228713] rk-vcodec ff650000.vpu_service: could not find power_model node
[    2.229382] rk-vcodec ff650000.vpu_service: init success
[    2.230314] rk-vcodec ff660000.rkvdec: no regulator for vcodec
[    2.231418] rk-vcodec ff660000.rkvdec: probe device
[    2.232115] rk-vcodec ff660000.rkvdec: drm allocator with mmu enabled
[    2.233120] rk-vcodec ff660000.rkvdec: could not find power_model node
[    2.233728] rk-vcodec ff660000.rkvdec: init success
[    2.235885] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.236593] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
[    2.238955] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
[    2.239669] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    2.241982] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    2.243206] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 35, base_baud = 1500000) is a 16550A
[    2.245062] [drm] Initialized drm 1.1.0 20060810
[    2.248929] [drm] Rockchip DRM driver version: v1.0.1
[    2.249743] rockchip-drm display-subsystem: defer getting devfreq
[    2.250616] rockchip-vop ff900000.vop: missing rockchip,grf property
[    2.251478] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffffff8008d82b10)
[    2.252259] rockchip-vop ff8f0000.vop: missing rockchip,grf property
[    2.253044] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffffff8008d82b10)
[    2.254042] i2c i2c-9: of_i2c: modalias failure on /hdmi@ff940000/ports
[    2.254709] dwhdmi-rockchip ff940000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.255535] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.257225] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffffff8008d77610)
[    2.257978] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.258619] [drm] No driver support for vblank timestamp query.
[    2.259390] rockchip-drm display-subsystem: failed to parse loader memory
[    2.388072] rockchip-vop ff900000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    2.509848] Console: switching to colour frame buffer device 240x67
[    2.590712] rockchip-drm display-subsystem: fb0:  frame buffer device
[    2.607579] Unable to detect cache hierarchy for CPU 0
[    2.609084] brd: module loaded
[    2.615542] loop: module loaded
[    2.616198] lkdtm: No crash points registered, enable through debugfs
[    2.618046] CAN device driver interface
[    2.619399] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    2.620055] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    2.620585] rk_gmac-dwmac fe300000.ethernet: RX delay(0x11).
[    2.621131] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    2.621895] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    2.622555] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    2.628133] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    2.628780] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    2.629248]  Ring mode enabled
[    2.629535]  DMA HW capability register supported
[    2.629961]  Normal descriptors
[    2.630276]  RX Checksum Offload Engine supported (type 2)
[    2.630796]  TX Checksum insertion supported
[    2.631193]  Wake-Up On Lan supported
[    2.631572]  Enable RX Mitigation via HW Watchdog Timer
[    2.705631] libphy: stmmac: probed
[    2.705955] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    2.706574] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    2.708358] usbcore: registered new interface driver rndis_wlan
[    2.709105] Rockchip WiFi SYS interface (V1.00) ...
[    2.709718] usbcore: registered new interface driver rtl8150
[    2.710308] usbcore: registered new interface driver r8152
[    2.710919] usbcore: registered new interface driver asix
[    2.711484] usbcore: registered new interface driver ax88179_178a
[    2.712117] usbcore: registered new interface driver cdc_ether
[    2.712726] usbcore: registered new interface driver rndis_host
[    2.713379] usbcore: registered new interface driver cdc_ncm
[    2.713967] usbcore: registered new interface driver cdc_mbim
[    2.722660] rockchip-dwc3 usb0: fail to get drvdata hcd
[    2.729706] rockchip-dwc3 usb1: fail to get drvdata hcd
[    2.731882] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.732525] ehci-pci: EHCI PCI platform driver
[    2.733026] ehci-platform: EHCI generic platform driver
[    2.737345] ehci-platform fe380000.usb: EHCI Host Controller
[    2.738125] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
[    2.739414] ehci-platform fe380000.usb: irq 28, io mem 0xfe380000
[    2.750392] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
[    2.751204] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.751857] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.752549] usb usb1: Product: EHCI Host Controller
[    2.753020] usb usb1: Manufacturer: Linux 4.4.167-gd6ee13d61c6d ehci_hcd
[    2.753662] usb usb1: SerialNumber: fe380000.usb
[    2.754783] hub 1-0:1.0: USB hub found
[    2.755178] hub 1-0:1.0: 1 port detected
[    2.759754] ehci-platform fe3c0000.usb: EHCI Host Controller
[    2.760545] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
[    2.761585] ehci-platform fe3c0000.usb: irq 30, io mem 0xfe3c0000
[    2.770403] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    2.771210] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.771863] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.772571] usb usb2: Product: EHCI Host Controller
[    2.773042] usb usb2: Manufacturer: Linux 4.4.167-gd6ee13d61c6d ehci_hcd
[    2.773685] usb usb2: SerialNumber: fe3c0000.usb
[    2.774757] hub 2-0:1.0: USB hub found
[    2.775149] hub 2-0:1.0: 1 port detected
[    2.776318] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    2.776931] ohci-platform: OHCI generic platform driver
[    2.777894] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
[    2.778814] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
[    2.779770] ohci-platform fe3a0000.usb: irq 29, io mem 0xfe3a0000
[    2.838588] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[    2.839251] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.839942] usb usb3: Product: Generic Platform OHCI controller
[    2.840510] usb usb3: Manufacturer: Linux 4.4.167-gd6ee13d61c6d ohci_hcd
[    2.841152] usb usb3: SerialNumber: fe3a0000.usb
[    2.842194] hub 3-0:1.0: USB hub found
[    2.842606] hub 3-0:1.0: 1 port detected
[    2.843743] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    2.844626] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
[    2.845552] ohci-platform fe3e0000.usb: irq 31, io mem 0xfe3e0000
[    2.902564] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[    2.903218] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.903909] usb usb4: Product: Generic Platform OHCI controller
[    2.904477] usb usb4: Manufacturer: Linux 4.4.167-gd6ee13d61c6d ohci_hcd
[    2.905119] usb usb4: SerialNumber: fe3e0000.usb
[    2.906168] hub 4-0:1.0: USB hub found
[    2.906587] hub 4-0:1.0: 1 port detected
[    2.908309] usbcore: registered new interface driver cdc_wdm
[    2.910453] usbcore: registered new interface driver usbtouchscreen
[    2.911499] .. rk pwm remotectl v1.1 init
[    2.912252] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/input0
[    2.914078] i2c /dev entries driver
[    2.916197] rk808 0-0020: Pmic Chip id: 0x8090
[    2.916989] rk808 0-0020: source: on=0x40, off=0x00
[    2.918432] rk808 0-0020: support dcdc3 fb mode:-22, -254811136
[    2.919158] rk808 0-0020: support pmic reset mode:0,0
[    2.919951] rk808 0-0020: no pinctrl handle
[    2.922775] rk808-regulator rk808-regulator: there is no dvs0 gpio
[    2.923464] rk808-regulator rk808-regulator: there is no dvs1 gpio
[    2.924240] DCDC_REG1: supplied by vcc5v0_sys
[    2.927831] DCDC_REG2: supplied by vcc5v0_sys
[    2.931550] DCDC_REG3: supplied by vcc5v0_sys
[    2.934475] DCDC_REG4: supplied by vcc5v0_sys
[    2.937744] DCDC_REG5: supplied by vcc5v0_sys
[    2.938796] vcc_buck5: Bringing 3300000uV into 2200000-2200000uV
[    2.942841] LDO_REG1: supplied by vcc_buck5
[    2.946621] LDO_REG2: supplied by vcc_buck5
[    2.950341] LDO_REG3: supplied by vcc_buck5
[    2.954102] LDO_REG4: supplied by vcc_buck5
[    2.955323] vcca_1v8: Bringing 1800000uV into 1850000-1850000uV
[    2.959642] LDO_REG5: supplied by vcc_buck5
[    2.960845] vdd1v5_dvp: Bringing 1800000uV into 1500000-1500000uV
[    2.966340] LDO_REG6: supplied by vcc_buck5
[    2.970750] LDO_REG7: supplied by vcc5v0_sys
[    2.974686] LDO_REG8: supplied by vcc5v0_sys
[    2.979162] LDO_REG9: supplied by vcc5v0_sys
[    2.983100] SWITCH_REG1: supplied by vcc5v0_sys
[    2.984230] SWITCH_REG2: supplied by vcc3v3_sys
[    2.987991] rk817-battery rk817-battery: Failed to find matching dt id
[    2.988934] rk817-charger rk817-charger: Failed to find matching dt id
[    2.996840] input: rk8xx_pwrkey as /devices/platform/ff3c0000.i2c/i2c-0/0-0020/input/input1
[    2.998074] rk808-rtc rk808-rtc: device is disabled
[    2.998594] rk808-rtc: probe of rk808-rtc failed with error -22
[    3.000935] fan53555-regulator 0-001c: FAN53555 Option[12] Rev[15] Detected!
[    3.001738] fan53555-reg: supplied by vcc5v0_sys
[    3.008167] fan53555-regulator 0-0010: FAN53555 Option[0] Rev[15] Detected!
[    3.008942] fan53555-reg: supplied by vcc5v0_sys
[    3.013720] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff80098e4000
[    3.019197] rtc-hym8563 2-0051: rtc core: registered hym8563 as rtc0
[    3.020363] rk3x-i2c ff120000.i2c: Initialized RK3xxx I2C bus at ffffff80098e6000
[    3.022486] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff80098e8000
[    3.024023] rk3x-i2c ff3e0000.i2c: Initialized RK3xxx I2C bus at ffffff80098ea000
[    3.026157] imx219 4-0010: Reading register 100 from 10 failed
[    3.026940] imx219 4-0010: Reading register 100 from 10 failed
[    3.034062] imx219 4-0010: Error -5 setting default controls
[    3.034669] imx219: probe of 4-0010 failed with error -5
[    3.036101] IR NEC protocol handler initialized
[    3.037868] rkisp1 ff910000.rkisp1: rkisp1 driver version: v00.01.01
[    3.038541] rkisp1 ff910000.rkisp1: Missing rockchip,grf property
[    3.041521] usbcore: registered new interface driver uvcvideo
[    3.042073] USB Video Class driver (1.1.1)
[    3.047634] Boot mode: coldboot
[    3.049353] rk_tsadcv2_temp_to_code: Invalid conversion table: code=1023, temperature=2147483647
[    3.050461] rockchip-thermal ff260000.tsadc: tsadc is probed successfully!
[    3.052005] dw_wdt ff848000.watchdog: Should better to setup a 'resets' property in dt, that must been named with reset
[    3.053363] Bluetooth: Virtual HCI driver ver 1.5
[    3.054004] Bluetooth: HCI UART driver ver 2.3
[    3.054461] Bluetooth: HCI UART protocol H4 registered
[    3.054954] Bluetooth: HCI UART protocol LL registered
[    3.055447] Bluetooth: HCI UART protocol ATH3K registered
[    3.056071] usbcore: registered new interface driver bfusb
[    3.056671] usbcore: registered new interface driver btusb
[    3.057203] rtk_btusb: Realtek Bluetooth USB driver ver 3.1.1d788ad.20181218-175024
[    3.057949] rtk_btcoex: Coex over UDP
[    3.058742] usbcore: registered new interface driver rtk_btusb
[    3.060031] cpu cpu0: leakage=25
[    3.073503] cpu cpu0: temp=40555, pvtm=147747 (147862 + -115)
[    3.075215] cpu cpu0: pvtm-volt-sel=1
[    3.076072] cpu cpu4: leakage=43
[    3.088781] cpu cpu4: temp=41111, pvtm=159609 (159609 + 0)
[    3.090105] cpu cpu4: pvtm-volt-sel=2
[    3.092534] cpu cpu0: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    3.094926] cpu cpu0: failed to find power_model node
[    3.097000] cpu cpu4: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0
[    3.099265] cpu cpu4: failed to find power_model node
[    3.100919] sdhci: Secure Digital Host Controller Interface driver
[    3.101510] sdhci: Copyright(c) Pierre Ossman
[    3.101935] Synopsys Designware Multimedia Card Interface Driver
[    3.103911] dwmmc_rockchip fe310000.dwmmc: IDMAC supports 32-bit address mode.
[    3.104769] dwmmc_rockchip fe310000.dwmmc: Using internal DMA controller.
[    3.105427] dwmmc_rockchip fe310000.dwmmc: Version ID is 270a
[    3.106063] dwmmc_rockchip fe310000.dwmmc: DW MMC controller at irq 25,32 bit host data width,256 deep fifo
[    3.107055] dwmmc_rockchip fe310000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.107942] dwmmc_rockchip fe310000.dwmmc: No vmmc regulator found
[    3.108534] dwmmc_rockchip fe310000.dwmmc: No vqmmc regulator found
[    3.109565] dwmmc_rockchip fe310000.dwmmc: allocated mmc-pwrseq
[    3.126510] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.142550] dwmmc_rockchip fe310000.dwmmc: 1 slots initialized
[    3.144171] dwmmc_rockchip fe320000.dwmmc: IDMAC supports 32-bit address mode.
[    3.146023] dwmmc_rockchip fe320000.dwmmc: Using internal DMA controller.
[    3.146725] dwmmc_rockchip fe320000.dwmmc: Version ID is 270a
[    3.149360] dwmmc_rockchip fe320000.dwmmc: DW MMC controller at irq 26,32 bit host data width,256 deep fifo
[    3.150337] dwmmc_rockchip fe320000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.151625] dwmmc_rockchip fe320000.dwmmc: No vmmc regulator found
[    3.153488] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    3.154405] rockchip-iodomain ff770000.syscon:io-domains: Setting to 3300000 done
[    3.170504] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.170565] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.187606] dwmmc_rockchip fe320000.dwmmc: 1 slots initialized
[    3.188634] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.191473] sdhci-arasan fe330000.sdhci: No vmmc regulator found
[    3.192050] sdhci-arasan fe330000.sdhci: No vqmmc regulator found
[    3.214521] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    3.226610] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
[    3.229606] ledtrig-cpu: registered to indicate activity on CPUs
[    3.231108] hidraw: raw HID events driver (C) Jiri Kosina
[    3.232459] usbcore: registered new interface driver usbhid
[    3.233008] usbhid: USB HID core driver
[    3.235800] rockchip-dmc dmc: unable to get devfreq-event device : dfi
[    3.242182] usbcore: registered new interface driver snd-usb-audio
[    3.244046] es8316 4-0011: Can not read property spk_ctl_gpio
[    3.244611] es8316 4-0011: Can not read property hp_det_gpio
[    3.246219] rk817-codec rk817-codec: rk817_codec_parse_dt_property() Can not get child: codec
[    3.247072] rk817-codec rk817-codec: rk817_platform_probe() parse device tree property error -19
[    3.253510] u32 classifier
[    3.253804] Netfilter messages via NETLINK v0.30.
[    3.254349] ip_set: protocol 6
[    3.255015] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.255545] Initializing XFRM netlink socket
[    3.256722] NET: Registered protocol family 10
[    3.258629] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.259157] NET: Registered protocol family 17
[    3.259608] NET: Registered protocol family 15
[    3.260072] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.261295] Bridge firewalling registered
[    3.261686] can: controller area network core (rev 20120528 abi 9)
[    3.262534] NET: Registered protocol family 29
[    3.263302] Bluetooth: RFCOMM socket layer initialized
[    3.263823] Bluetooth: RFCOMM ver 1.11
[    3.264199] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.264768] Bluetooth: HIDP socket layer initialized
[    3.265246] 8021q: 802.1Q VLAN Support v1.8
[    3.265669] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.266662] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.267205] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6256
[    3.267858] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.268535] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.269334] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 3, flags = 0.
[    3.270196] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[    3.270906] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.271407] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.271929] [BT_RFKILL]: Enter rfkill_rk_init
[    3.272925] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 83.
[    3.273735] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 92.
[    3.274534] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 90.
[    3.275314] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 5.
[    3.276090] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    3.276790] [BT_RFKILL]: Request irq for bt wakeup host
[    3.277339] [BT_RFKILL]: ** disable irq
[    3.277873] [BT_RFKILL]: bt_default device registered.
[    3.278469] Key type dns_resolver registered
[    3.279879] Registered cp15_barrier emulation handler
[    3.280523] Registered setend emulation handler
[    3.283315] bootconsole [uart0] disabled
This help you fix the issue.https://wiki.radxa.com/RockpiN10/dev/Debian#FAQs
I connected a monitor, but no output. So I think this is not a same problem.
Anyway, I will modify dts file and retry.
