Can I boot ROCK 5B with NVMe SSD only?
What size NVMe SSD can I use?
you can only boot linux with nvme only right now.
Thanks you for your reply.
Is the SSD size Type 2280?
Yes, the only one mount point is 2280
by the way, boot from nvme maybe have huge pd handshake issue rightnow
我已经体会到了,如果电源不足将会无限重启
这倒不是供电不足,实测18W的pd充电头不带nvme的话都能跑,问题在于从上电到内核开始协商的这个时间差
所以,这是一个bug,那可以反馈给官方吗?
这事情从dev版本开始就发现了,目前预计的解决方案是把协商放到uboot,官方正在做
那就只有慢慢等官方修复吧,
Is boot from m.2 slot, only possible for NVMe, or any M.2 SSD (sata) can work too?
only nvme.
there is no sata m.2 ssd support on 5b.
No sata as at the current moment or no sata m.2 ssd support maybe also in the future?
the m.2 solt on bottom only support nvme.
it only has pcie circuit. it can’t support sata.
Oke, so what you are saying is it does NOT support M.2 NGFF (SATA)?
Because that is what i am talking about. If you need that other type, there is i believe a SATA hat or zo.
i means that you could not direct insert m2 sata ssd to any slots on the board.
the m2 slot on the top has a adapter card to convert to a sata jack, but you should use an externel power to drive the ssd.
And that is against Toms Hardware article about Rock 5B introduction.
if you do not believe me, you can test it yourself.
by the way, because of the board not support use sata direct, there is no sata boot support right now, and i had not heard any message said radxa or rockchip will do something let the board support boot from sata.
so sata ssd can only use as extended storage.
