Can bus with rock5
I’m trying to run the built-in can bus. I’m using armbian. I added interface information to the dtsi file and built the system. When I started the system, I saw that this information was in the device tree, but the can bus didn’t start. Maybe someone could suggest something?
I took the interface information from the rockchip kernel
can1: can@fea60000 {
compatible = “rockchip,can-2.0”;
reg = <0x0 0xfea60000 0x0 0x1000>;
interrupts = <GIC_SPI 342 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_CAN1>, <&cru PCLK_CAN1>;
clock-names = “baudclk”, “apb_pclk”;
resets = <&cru SRST_CAN1>, <&cru SRST_P_CAN1>;
reset-names = “can”, “can-apb”;
pinctrl-names = “default”;
pinctrl-0 = <&can1m0_pins>;
tx-fifo-depth = <1>;
rx-fifo-depth = <6>;
status = “disabled”;
I also set up an overlay when the system starts, which puts the interface into the “okay” state
rockchip has abandoned maintenance CAN in the 6.1 kernel
Joshua Rieks 6.1 kernel had some fixes for can bus
