Hello, The document: https://dl.radxa.com/cm3/docs/Radxa_CM3_datasheet_brief_v1.1.pdf specifies that CM3 features a CAN bus. However, when I look to CM3 pinout, I don’t see any pin related to CAN.
Is CAN bus supported on CM3? If so, what are the pins and how can I use it?
CM3 has no CAN bus since RK3566 does not support it. CM3 Industrial will support CAN bus since that uses the same RK3568 as ROCK 3A which has CAN bus support.
Here is the updated product brief: https://dl.radxa.com/cm3/docs/Radxa_CM3_datasheet_brief_v1.3.pdf
Sorry for the confusion.
