Can Boot From One uSD But Not Another
Have a PNY 32GB microSDHC and a SanDisk 16GB microSDHC, both being flashed with etcher, both using Armbian_22.08.0-trunk_Radxa-zero_focal_current_5.10.119_xfce_desktop.img.xz. The PNY loads just fine, but the SanDisk will not despite multiple attempts. Also attempted to flash the image with Rufus with the flag for checking bad blocks on and the SanDisk passed.
Debug for reference:
G12A:BL:0253b8:61aa2d;FEAT:E0F83180:2000;POC:F;RCY:0;EMMC:800;NAND:81;SD?:0;SD:0;READ:0;0.0
                                        l2_stage_init 0x01
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
no sdio debug board detected
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 254391
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
board id: 2
Load FIP HDR from SD, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from SD, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from SD, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
fastboot data verify
verify result: 266
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from SD, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0
dmc_version 0000
Check phy result
1D training failed
LPDDR4 probe
ddr clk to 792MHz
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from SD, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
channel==0
RxClkDly_Margin_A0==256 ps 13
TxDqDly_Margin_A0==256 ps 13
RxClkDly_Margin_A1==0 ps 0
TxDqDly_Margin_A1==0 ps 0
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==31
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==0
DeviceVref_Margin_A1==0
channel==1
RxClkDly_Margin_A0==236 ps 12
TrainedVREFDQ_A1==0
VrefDac_Margin_A0==32
soc_vref_reg_value 0x 00000019 00000018 0000001b 0000001a 0000001b 0000001a 00000019 0000001c 0000001a 00000018 0000001a 0000001a 00000019 0000001b 00000019 0000001b 0000001c 00000019 0000001d 0000001b 0000001c 0000001b 0000001b 0000001a 00000018 0000001a 0000001b 00000018 00000017 00000017 00000016 00000017 dram_vref_reg_value 0x 00000061
2D training succeed
auto size-- 65535DDR cs0 size: 1024MB
DDR cs1 size: 0MB
DMC_DDR_CTRL: 00c0002bDDR size: 1024MB
cs0 DataBus test pass
cs0 AddrBus test pass
100bdlr_step_size ps== 481
result report
Load FIP HDR from SD, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from SD, src: 0x0006c200, des: 0x0175c000, size: 0x00098000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 02 23 00 00 19 35 36 32 43 46 50
[0.017149 Inits done]
secure task start!
high task start!
low task start!
run into bl31
NOTICE:  BL31: v1.3(release):4fc40b1
NOTICE:  BL31: Built : 15:57:33, May 22 2019
NOTICE:  BL31: G12A normal boot!
NOTICE:  BL31: BL33 decompress pass
U-Boot 2022.01-armbian (Jun 02 2022 - 02:57:04 +0000) radxa-zero
Model: Radxa Zero
SoC:   Amlogic Meson G12A (S905Y2) Revision 28:c (30:2)
DRAM:  1 GiB
MMC:   sd@ffe03000: 0, sd@ffe05000: 1, mmc@ffe07000: 2
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
8025 bytes read in 3 ms (2.6 MiB/s)
## Executing script at 08000000
U-boot default fdtfile: amlogic/meson-g12a-radxa-zero.dtb
Current variant:
126 bytes read in 1 ms (123 KiB/s)
Current fdtfile after armbianEnv: amlogic/meson-g12a-radxa-zero.dtb
Mainline bootargs: root=UUID=066eff29-ee04-40cc-8504-64a7b298c01d rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyAML0,115200 console=tty1 consoleblank=0 coherent_pool=2M loglevel=1 ubootpart=ba50b4a9-01 libata.force=noncq usb-storage.quirks=    cgroup_enable=memory swapaccount=1
 ** fs_devread read error - block
Failed to load '/boot/uInitrd'
Failed to mount ext2 filesystem...
Can't set block device
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Bad Linux ARM64 Image magic!
SCRIPT FAILED: continuing...
** No partition table - mmc 1 **
Couldn't find partition mmc 1:1
Scanning disk [email protected]...
Disk [email protected] not ready
Found 1 disks
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-meson-u200
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Please give this test build of U-Boot a try and see if that solves your issue: Trying to figure out whats wrong with my radxa zero
Once we get more feedback on the effectiveness of this fix we will looking to have it as part of our image.
Thanks for the reply Yuntian, when I get some time I’ll test it out and mark your reply as the solution if it works.
Finally had time to test this. Took me a bit to realize I shouldn’t be trying to follow the other post exactly, as it is specific to boards with the eMMC. Just had to pull the uSD, pop it into a USB uSD reader, then into my Ubuntu test machine, and run the dd commands against the /dev disk. After that the SanDisk 16GB microSDHC works great! Thanks Yuntian!
