Camera OV5647 error
Dear,
I activate overlay Raspberry camera 1.3 on my Zero 3W (BullEye) when i execute this command:
gst-launch-1.0 v4l2src device=/dev/video11 io-mode=4 ! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080 ! jpegenc ! multifilesink location=file.name.jpg;
Setting pipeline to PAUSED ...
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Cannot identify device '/dev/video11'.
Additional debug info:
../sys/v4l2/v4l2_calls.c(608): gst_v4l2_open (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
system error: No such file or directory
ERROR: pipeline doesn't want to preroll.
Failed to set pipeline to PAUSED.
Setting pipeline to NULL ...
Freeing pipeline ...
I get this error, how can i resolve please?
try with
device=/dev/video0
And it should be something like:
gst-launch-1.0 v4l2src device=/dev/video0 io-mode=dmabuf num-buffers=1 ! video/x-raw,format=NV12,width=640,height=480 ! mppjpegenc ! filesink location=file.name.jpg
I have the same problem /dev/video0 not recognized:
radxa@radxa-zero3:~$ ls /dev/video*
/dev/video-enc0
/dev/video-dec0
So i boot with other OS system Bookworm KDE, less issues on this OS.
radxa@radxa-zero3:~$ gst-launch-1.0 v4l2src device=/dev/video0 io-mode=dmabuf num-buffers=1 ! video/x-raw,format=NV12,width=640,height=480 ! mppjpegenc ! filesink location=file.name.jpg
Pipeline is live and does not need PREROLL ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
rga_api version 1.10.1_[4]
Redistribute latency...
Got EOS from element "pipeline0".
Execution ended after 0:00:00.657538604
Now, when i open file.name.jpg, it’s black screen.
/dev/video0  /dev/video2  /dev/video4  /dev/video6  /dev/video8  /dev/video-camera0  /dev/video-enc0
/dev/video1  /dev/video3  /dev/video5  /dev/video7  /dev/video9  /dev/video-dec0
check the output of
ls -la /dev/video-camera0
maybe you should enable the camera with rsetup?
radxa@radxa-zero3:~$ ls -la /dev/video-camera0
lrwxrwxrwx 1 root root 6 Jul 24 11:17 /dev/video-camera0 -> video0
I enable my camera on rsetup:
radxa@radxa-zero3:~$ journalctl -xb > test.txt
journalctl.zip (15.6 KB)
Check the output of:
sudo systemctl status rkaiq_3A
radxa@radxa-zero3:~$ sudo systemctl status rkaiq_3A
● rkaiq_3A.service - Enable Rockchip camera engine rkaiq
 Loaded: loaded (/lib/systemd/system/rkaiq_3A.service; enabled; preset: enabled)
 Active: active (running) since Thu 2025-07-24 11:17:43 CEST; 24h ago
  Tasks: 9 (limit: 4660)
 Memory: 10.3M
    CPU: 279ms
 CGroup: /system.slice/rkaiq_3A.service
         ├─308 /usr/bin/rkaiq_3A_server
         └─309 logger -t rkaiq
Jul 24 11:17:44 radxa-zero3 rkaiq[309]: DBG: /dev/media0: wait stream start event...
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: /dev/media0: wait stream start event success ...
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: device manager start
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: CAMHW:K:cid[0] start success. isGroup:0, isOnline:1, isMultiIsp:0, init_ens:0x1bf88>
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: XCORE:K:cid[0] rk_aiq_uapi_sysctl_start success.
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: rkisp_init engine succeed
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: /dev/media0: wait stream stop event...
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: /dev/media0: wait stream stop event success ...
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: XCORE:K:cid[0] rk_aiq_uapi_sysctl_stop success.
Jul 24 14:10:55 radxa-zero3 rkaiq[309]: DBG: /dev/media0: wait stream start event...
Everything looks fine.
My last guess is that the iqfile for OV5647 is not compatible with the kernel version you are using.
You may check this by doing:
1 - Stop the camera engine
sudo systemctl stop rkaiq_3A
2- point the camera at a strong light source (powerful)
Take the photo and check the picture
3- try using cheese or ffplay to double check
if it is still black, check the sensor with:
sudo dmesg|grep -i ov
and
sudo dmesg|grep -i isp
  1. i point a strong light, the picture display my light with black background.
radxa@radxa-zero3:~$ sudo dmesg|grep -i ov
[103308.106643] ov5647 2-0036: stream start
[103308.106653] ov5647 2-0036: OV5647 power on
[103308.789815] ov5647 2-0036: stream stop
[103308.791294] ov5647 2-0036: OV5647 power off
[103314.282395] ov5647 2-0036: stream start
[103314.282406] ov5647 2-0036: OV5647 power on
[103314.968303] ov5647 2-0036: stream stop
[103314.969698] ov5647 2-0036: OV5647 power off
radxa@radxa-zero3:~$ sudo dmesg|grep -i isp
[103307.079405] rkisp_hw fdff0000.rkisp: set isp clk = 297000000Hz
[103308.106517] rkisp-vir0: waiting on params stream on event timeout
[103308.729376] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.729435] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.735909] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.735941] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.736000] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.737242] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.737333] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.737366] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.737561] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.737658] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.742151] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.742243] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.742273] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.742602] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.742729] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.743803] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.743931] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.744224] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.744320] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.744353] rkisp-vir0: MIPI error: packet: 0x01000000
[103308.789631] rkisp-vir0: MIPI error: packet: 0x00000100
[103313.270593] rkisp_hw fdff0000.rkisp: set isp clk = 297000000Hz
[103314.282270] rkisp-vir0: waiting on params stream on event timeout
[103314.907600] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.907633] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.907723] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.908019] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.908115] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.908146] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.914037] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.914065] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.914161] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.914209] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915464] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915494] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915592] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915621] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915786] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.915915] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.940650] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.940712] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.940745] rkisp-vir0: MIPI error: packet: 0x01000000
[103314.968116] rkisp-vir0: MIPI error: packet: 0x00000100
“The error code 0x01000000 often points to a synchronization or data integrity issue within the MIPI stream.”
I would suggest downgrading the kernel version if possible.
I have this kernel:
radxa@radxa-zero3:~$ uname -a
Linux radxa-zero3 6.1.84-10-rk2410-nocsf #10 SMP Mon Jul 14 10:45:01 UTC 2025 aarch64 GNU/Linux
