Camera-engine-rkaiq
There are a lot of Problems with the Camera-Engine/isp on the Ubuntu images.
When using the IMX415 Camera and having enabled the kernel overlay the radxa version 3.0x8.9
Does not work at all also the older versions or the one published by rockchip all end in a
( 1. Segmentation fault (core dumped))
rkaiq log level ff0
media get entity by name: stream_cif_dvp_id0 is null
media get entity by name: stream_cif_dvp_id1 is null
media get entity by name: stream_cif_dvp_id2 is null
media get entity by name: stream_cif_dvp_id3 is null
media get entity by name: rkcif-mipi-luma is null
media get entity by name: rkcif-lvds-subdev is null
media get entity by name: rkcif-lite-lvds-subdev is null
media get entity by name: rockchip-mipi-dphy-rx is null
media get entity by name: stream_cif is null
media get entity by name: rkcif-dvp-sof is null
media get entity by name: rkisp-csi-subdev is null
media get entity by name: rkisp-mpfbc-subdev is null
media get entity by name: rkisp_rawwr0 is null
media get entity by name: rkisp_rawwr1 is null
media get entity by name: rkisp_rawwr2 is null
media get entity by name: rkisp_rawwr3 is null
media get entity by name: rkisp_dmapath is null
media get entity by name: rkisp-mipi-luma is null
media get entity by name: rockchip-csi2-dphy0 is null
media get entity by name: rkcif_dvp is null
media get entity by name: rkcif_lite_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds is null
media get entity by name: rkcif_mipi_lvds1 is null
media get entity by name: rkcif_mipi_lvds2 is null
media get entity by name: rkcif_mipi_lvds3 is null
media get entity by name: rkcif_mipi_lvds4 is null
media get entity by name: rkcif_mipi_lvds5 is null
media get entity by name: rkcif-mipi-lvds is null
media get entity by name: rkcif-mipi-lvds1 is null
media get entity by name: rkcif-mipi-lvds3 is null
media get entity by name: rkcif-mipi-lvds4 is null
media get entity by name: rkcif-mipi-lvds5 is null
media get entity by name: rkisp-isp-subdev is null
media get entity by name: rkisp-input-params is null
media get entity by name: rkisp-statistics is null
media get entity by name: rkisp_mainpath is null
Cound not find rkisp dev names, skipped /dev/media0
ERR: Bad media topology for: /dev/media0
DBG: get rkisp-isp-subdev devname: /dev/v4l-subdev3
DBG: get rkisp-input-params devname: /dev/video19
DBG: get rkisp-statistics devname: /dev/video18
DBG: get rkisp_mainpath devname: /dev/video11
ERR: Bad media topology for: /dev/media2
ERR: Bad media topology for: /dev/media3
ERR: Bad media topology for: /dev/media4
ERR: Bad media topology for: /dev/media5
ERR: Bad media topology for: /dev/media6
ERR: Bad media topology for: /dev/media7
ERR: Bad media topology for: /dev/media8
ERR: Bad media topology for: /dev/media9
ERR: Bad media topology for: /dev/media10
ERR: Bad media topology for: /dev/media11
ERR: Bad media topology for: /dev/media12
ERR: Bad media topology for: /dev/media13
ERR: Bad media topology for: /dev/media14
ERR: Bad media topology for: /dev/media15
The ISP stays off and the image is not tuned at all.
When using the older version ( https://github.com/radxa/debos-radxa/raw/main/rootfs/packages/arm64/camera/camera-engine-rkaiq_3.0.2_arm64.deb) which is in the debos-radxa rootfs it works.
Now the interesting part, when switching the the quite popular ubuntu version by Joshua-Riek, it is even worse. The 3.0.2 version works, but the ISP is constantly acting up:
Usually rkaiq_3A_server crashes with “Segmentation fault” when no compatible JSON-file in /etc/iqfiles directory for your camera. I have encountered similar problem on FriendlyELEC board, which contained librkaiq.so of some strange version 5. After I compiled rkaiq_3A_server and librkaiq.so of version 3, the problem was gone.
So it seems that new versions of librkaiq.so use different format of camera’s JSON-files.
