Bullseye network config error
Installing bullseye firmware from radxa-website does not config the network-devices correctly. The output in serial console is:
[ 330.480088] rkgmac-dwmac fe010000.ethernet: Failed to reset the dma
[ 330.480226] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 330.480281] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 331.550788] rk_gmac-dwmac e010000.ethernet: Failed to reset the dma
[ 331.550877] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_hw_setup: DMA engine initialization failed
[ 331.550898] rk_gmac-dwmac fe010000.ethernet eth0: stmmac_open: Hw setup failed
[ 332.574672] rk_gmac-dwmac fe2a0000.ethernet: Failed to reset the dma
What’s wrong …
Try those Radxa E25 - Armbian
With armbian the board works … thank’s a lot for the hint.
