There is now a buildroot OS available for the RockPi E.
Hi Flatmax,
Your repo says
# For the RockPi E (rk3328 based board) [needs more work]
I am new to buildroot but would like to help. Can you give me an idea of the kinds of things that need to be worked on?
David
You could still use buildroot to create root filesystem.
At the moment, i compile kernel and u-boot and rootfs manually, then using dd
i will create bootable image for rk3328 based board.
