Hi everyone, I am trying to compile uboot for rockpi 4a and I have the following error:
./build/mk-uboot.sh rockpi4a
CC arch/arm/mach-rockchip/rk3399/clk_rk3399.o
CC arch/arm/mach-rockchip/rk3399/rk3399.o
CC arch/arm/mach-rockchip/rk3399/syscon_rk3399.o
LD arch/arm/mach-rockchip/rk3399/built-in.o
CC arch/arm/mach-rockchip/rk_atags.o
LD arch/arm/mach-rockchip/built-in.o
CC board/rockchip/evb_rk3399/evb-rk3399.o
board/rockchip/evb_rk3399/evb-rk3399.c:168:13: error: 'rk3399_force_pcie_power_on' defined but not used [-Werror=unused-function]
static void rk3399_force_pcie_power_on(void)
cc1: all warnings being treated as errors
scripts/Makefile.build:280: recipe for target 'board/rockchip/evb_rk3399/evb-rk3399.o' failed
make[2]: *** [board/rockchip/evb_rk3399/evb-rk3399.o] Error 1
Makefile:1287: recipe for target 'board/rockchip/evb_rk3399' failed
make[1]: *** [board/rockchip/evb_rk3399] Error 2
make: *** [__build_one_by_one] Error 2
Makefile:461: recipe for target '__build_one_by_one' failed
And the per the documentation linked above, the branch rk3399-pie-gms-express-baseline gives the following error:
CC common/s_record.o
CC common/xyzModem.o
CC common/write_keybox.o
CC common/keymaster.o
CC common/attestation_key.o
LD common/built-in.o
CC disk/part.o
CC disk/part_dos.o
CC disk/part_efi.o
disk/part_efi.c: In function ‘gpt_verify_partitions’:
disk/part_efi.c:858:49: error: taking address of packed member of ‘struct _gpt_entry’ may result in an unaligned pointer value [-Werror=address-of-packed-member]
858 | gpt_convert_efi_name_to_char(efi_str, gpt_e[i].partition_name,
make[2]: *** [scripts/Makefile.build:281: disk/part_efi.o] Error 1
make[1]: *** [Makefile:1289: disk] Error 2
make: *** [Makefile:461: __build_one_by_one] Error 2
MAKE UBOOT IMAGE FAILED.
