Build my own armbian
I try to build my own raspbian for Radxa zero (v1.51, no emmc, 512M)
I have no trouble to build raspbian:
[ o.k. ] Done building [ /home/xxxxxx/build/.tmp/image-2c96ef55-de3a-48b4-8be8-3d0002958ee1/Armbian_22.11.0-trunk_Radxa-zero_bullseye_current_5.19.17_minimal.img ]
[ o.k. ] Runtime [ 32 min ]
[ o.k. ] Repeat Build Options [ ./compile.sh  BOARD=radxa-zero BRANCH=current RELEASE=bullseye BUILD_MINIMAL=yes BUILD_DESKTOP=no KERNEL_ONLY=no KERNEL_CONFIGURE=no COMPRESS_OUTPUTIMAGE=sha,gpg,img  ]
When I launch the image, I have this error :
=> boot
starting USB...
Starting the controller
USB XHCI 1.10
scanning bus usb@ff500000 for devices... 1 USB Device(s) found
Device 0: unknown device
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
8147 bytes read in 4 ms (1.9 MiB/s)
## Executing script at 08000000
U-boot default fdtfile: amlogic/meson-g12a-radxa-zero.dtb
Current variant:
** Reading file would overwrite reserved memory **
Failed to load '/boot/armbianEnv.txt'
"Synchronous Abort" handler, esr 0x96000010
elr: 0000000001062fb0 lr : 0000000001060ef4 (reloc)
need I to play some patchs from here : https://github.com/radxa/armbian-build ?
This post wasn’t helpful, My Armbian Build can not boot on Radxa Zero.
Can you help please
Thanks
Armbian is not Raspbian, Raspbian = https://www.raspbian.org/ “debian for Rpi”
If you are trying to generate Armbian image for Radxa Zero, perhaps try to ask at Armbian support?
oups, I want to say Armbian. Typo error Sorry.
Thanks Igor for your reply.
I think the problem is radxa zero conf here. I use Armbian with another board and I have no trouble when I build the basic option.
Have you or someone else try to build armbian recently with this board?
Thanks
Config is just fine, but code that is used to build image is changing and Radxa generally does not maintain that. You will need to check Armbian forums and Armbian Discord channels, in particular #armbian-amlogic for clues and tips what to try. I can’t verify.
