Rock5b on recommend Radxa Supply.
No problems on fresh install on emmc using “RKDEvTool”.
sudo apt-get update && apt-get upgrade … Stucking in Bootloop.
Uart-Debug:
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-557-g9609b9c19:derrick.huang
NOTICE: BL31: Built : 14:29:57, Mar 8 2023
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
ERROR: Error
[ 6.417664] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 6.417678] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 6.417686] fiq_debugger_probe: could not install nmi irq handler
[ 7.156229] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 7.156575] rk-pcie fe170000.pcie: IRQ msi not found
[ 7.156599] rk-pcie fe170000.pcie: Missing config reg space
[ 7.156741] rk-pcie fe170000.pcie: Missing config reg space
[ 7.156782] rk-pcie fe170000.pcie: invalid resource
[ 7.156943] rk-pcie fe150000.pcie: IRQ msi not found
[ 7.156966] rk-pcie fe150000.pcie: Missing config reg space
[ 7.157096] rk-pcie fe150000.pcie: Missing config reg space
[ 7.157133] rk-pcie fe150000.pcie: invalid resource
[ 7.157845] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 7.157853] rkvdec2_init:1008: No niu aclk reset resource define
[ 7.157860] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 7.157865] rkvdec2_init:1011: No niu hclk reset resource define
[ 7.158510] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 7.158518] rkvdec2_init:1008: No niu aclk reset resource define
[ 7.158524] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 7.158530] rkvdec2_init:1011: No niu hclk reset resource define
[ 7.416247] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy pll locked!
[ 7.416503] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy lane locked!
[ 7.668544] rk806 spi2.0: no sleep-setting state
[ 7.668599] rk806 spi2.0: no reset-setting pinctrl state
[ 7.668637] rk806 spi2.0: no dvs-setting pinctrl state
[ 7.959075] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 7.975631] rksfc_base v1.1 2016-01-08
[ 8.027552] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 8.027658] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 8.028527] rockchip-dmc dmc: could not find power_model node
[ 8.037256] rk-pcie fe190000.pcie: IRQ msi not found
[ 8.037394] rk-pcie fe190000.pcie: Missing config reg space
[ 8.037677] rk-pcie fe190000.pcie: Missing config reg space
[ 8.037835] rk-pcie fe190000.pcie: invalid resource
[ 8.040481] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 8.040555] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 8.040610] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 8.045273] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 8.076070] RKNPU fdab0000.npu: failed to find power_model node
[ 8.076177] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 8.076259] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
▒DDR Version V1.08 20220617
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB
Manufacturer ID:0x6
CH0 RX Vref:29.7%, TX Vref:23.8%,0.0%
CH1 RX Vref:28.7%, TX Vref:23.8%,0.0%
CH2 RX Vref:28.7%, TX Vref:23.8%,0.0%
CH3 RX Vref:29.7%, TX Vref:23.8%,0.0%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
