I brake the SD Card slot on my brand new PI4 :(
I will order a eMMC Module
but meanwhile:
With rufus i writhed the debian image to an usb stick but the pi4 ist not booting with it.
is this possible to run it from an usbstick?
greetings
but meanwhile:
greetings
As for now it’s not possible to run all from usb stick. Boot partition still needs to be on emmc or sdcard. To boot from usb… Maybe you need to use maskrom mode, but i don’t experience with it, so can’t help much
http://rockchip.wikidot.com/boot-from-udisk
Blockquote
please note that u-boot aren’t allowed to boot from usb-disk because of the maskrom’s limition, only kernel and rootfs can load from usb-disk.
http://opensource.rock-chips.com/wiki_Boot_option
looks like it is not possible, so I will wait for the emmc
@pumuckll, can you please post a picture of the broken SD-Card reader?
I’d be interested to see how it broke.
Can you also explain a bit how it happened?
The Metal Cover was Borken, when I removed the case. Because the ad card looks out off the case.
![15566289446858751851925271862180|666x500]
(upload://zaB3NWnezUYOVupgQ50lTCtr56l.jpeg)I use the emmc now , it is ok for me.
Ok, thanks for posting
Hi pumuckll. I was wondering if you managed to replace the SD card slot in the end.
I got the same problem and as you
, now I am using eMMC to boot.
However, I have also NVMe attached and it is annoying having to dismantle everything each time I need to reinstall or change OS so being able to fix a new SD card slot would be a perfect solution ![]()
Regards
M
i tried to solder the broken part, but I stopped it .
The riskt too damgeit was to high for me.
I ordered an emmc card, now it woks without any problem.
greetings
