Now the Intel Optane Memory is really cheap (from taobao.com,an 16GB one cost about only 10 dollers)
When I got the board(with nothing inside the on-board SPI flash),I flashed the latest ubuntu server image to a sd card,and when the ssd is connected, the board will no longer boot EVEN THE SSD IS 100% EMPTY (after dd if=/dev/zero of=/dev/nvme0n1);
Below is the boot log I got using a serial converter.
DDR Version 1.20 20190314
In
soft reset
SRX
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
Channel 0: LPDDR4,800MHz
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,800MHz
256B stride
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
Boot1: 2018-06-26, version: 1.14
CPUId = 0x0
ChipType = 0x10, 279
Spi_ChipId = b4016
SpiBootInit:0
mmc0:cmd5,32
SdmmcInit=0 0
BootCapSize=0
UserCapSize=7620MB
FwPartOffset=2000 , 0
StorageInit ok = 21755
SecureMode = 0
SecureInit ret = 0, SecureMode = 0
GPT signature is wrong
LoadTrust Addr:0x1800
LoadTrust Addr:0x1c00
LoadTrust Addr:0x2000
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 1000
hdr 00000000031912c0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
tag:LOADER error,addr:0x3000
Load uboot, ReadLba = 1400
tag:LOADER error,addr:0x3400
Load uboot, ReadLba = 1800
tag:LOADER error,addr:0x3800
Load uboot, ReadLba = 1c00
tag:LOADER error,addr:0x3c00
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xef390
RunBL31 0x10000
NOTICE: BL31: v1.3(debug):1b26c3f
NOTICE: BL31: Built : 20:53:30, Dec 26 2018
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1181): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-02680-g674eaa57f0 (Sep 23 2019 - 04:05:05 +0000), Build: jenkins-linux-build-testing-2-43
Model: Rockchip RK3399 rockpi4b Board
PreSerial: 2
DRAM: 3.9 GiB
Relocation Offset is: f5bdf000
Sysmem: init
I2c speed: 400000Hz
PMIC: RK808
vdd-center init 950000 uV
MMC: dwmmc@fe320000: 1, sdhci@fe330000: 0
Using default environment
dcache off
"Synchronous Abort" handler, esr 0x96000210
* Relocate offset = 00000000f5bdf000
* ELR(PC) = 0000000000256124
* LR = 0000000000256114
* SP = 00000000e9dc92d0
* ESR_EL2 = 0000000096000210
EC[31:26] == 100101, Exception from a Data abort, from current exception level
IL[25] == 1, 32-bit instruction trapped
* DAIF = 00000000000003c0
D[9] == 1, DBG masked
A[8] == 1, ABORT masked
I[7] == 1, IRQ masked
F[6] == 1, FIQ masked
* SPSR_EL2 = 0000000060000349
I[7] == 0, IRQ not masked
M[4] == 0, Exception taken from AArch64
M[3:0] == 1001, EL2h
* SCTLR_EL2 = 0000000030c51830
I[12] == 1, Icaches enabled
C[2] == 0, Dcache disabled
M[0] == 0, MMU disabled
* HCR_EL2 = 000000000800003a
* VBAR_EL2 = 00000000f5ddf800
* TTBR0_EL2 = 00000000f7ff0000
x0 : 00000000e9e03c60 x1 : 0000000000100008
x2 : 00000000f8000000 x3 : 0000000000c000e8
x4 : 00000000fd000000 x5 : 00000000fd000000
x6 : 0000000000000001 x7 : 0000000000000001
x8 : 00000000fa000000 x9 : 0000000000000008
x10: 0000000000000007 x11: 00000000e9dc9c40
x12: 0000000000000cb2 x13: 0000000000000ca0
x14: 00000000e9dc941c x15: 00000000e9dc9c40
x16: 00000000e21620cc x17: 0000000000d3c854
x18: 00000000e9dd6d80 x19: 00000000e9e03c60
x20: 00000000000007b6 x21: 00000000e9dee9f0
x22: 00000000000007d0 x23: 0000000000000002
x24: 0000000000000002 x25: 00000000e9e01b50
x26: 0000000000000000 x27: 0000000000000000
x28: 00000000e9e01bb0 x29: 00000000e9dc94b0
SP:
e9dc92d0: 00000000 00000000 00000000 00000000
e9dc92e0: 00000000 00000000 f5e9b48b 00000000
e9dc92f0: 00000000 00000000 00000000 00000000
e9dc9300: f5e9b4d2 00000000 f5e9b4f8 00000000
e9dc9310: f5e9b545 00000000 f5e9b592 00000000
e9dc9320: f5e9b5d2 00000000 f5e9b612 00000000
e9dc9330: f5e9b64f 00000000 00000000 00000000
e9dc9340: 00000000 00000000 f5e9b68c 00000000
e9dc9350: e9dc94b0 00000000 f5ddfa0c 00000000
e9dc9360: e9e03c60 00000000 004bd004 00014400
e9dc9370: f7ff0000 00000000 0800003a 00000000
e9dc9380: 30c51830 00000000 e9dc92d0 00000000
e9dc9390: 60000349 00000000 f5ddf800 00000000
e9dc93a0: 000003c0 00000000 96000210 00000000
e9dc93b0: f5e35124 00000000 e9e03c60 00000000
e9dc93c0: 00100008 00000000 f8000000 00000000
Call trace:
PC: [< 00256124 >]
LR: [< 00256114 >]
Stack:
[< 00256124 >]
[< 002309e8 >]
[< 00231aac >]
[< 00231da0 >]
[< 00254ec4 >]
[< 0020c904 >]
[< 00229980 >]
[< 00214f1c >]
[< 002150c0 >]
[< 002147cc >]
[< 00228f68 >]
[< 00229980 >]
[< 00214f1c >]
[< 002150c0 >]
[< 002147cc >]
[< 00228ed0 >]
[< 00202bd4 >]
[< 00227b88 >]
[< 00203740 >]
[< 00203984 >]
[< 00202f78 >]
[< 00277c14 >]
[< 00215eec >]
[< 00201b8c >]
NOTE: Please use ./scripts/stacktrace.sh to parse trace info
Resetting CPU ...
Note:The Armbian image works perfectly with the ssd useable in linux.
