Tried to use a couple of images (Armbian + Bullseye) but it fails to boot. I attached serial debugger and got the follow, it’s stuck at “Starting Kernel”.
�DDR Version 1.25 20210517
In
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 1
CS = 0
MR0=0x19
MR4=0x3
MR5=0x6
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0xFF
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
change freq to 666MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 666MHZ, ctl_index 1
support 416 328 666 MHz, current 666MHz
OUT
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 369
mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000
mmc: ERROR: Card did not respond to voltage select!
emmc reinit
emmc reinit
SdmmcInit=2 1
mmc0:cmd5,20
SdmmcInit=0 0
BootCapSize=0
UserCapSize=14940MB
FwPartOffset=2000 , 0
StorageInit ok = 46011
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
SecureInit ret = 0, SecureMode = 0
atags_set_bootdev: ret:(0)
GPT 0x3335db8 signature is wrong
recovery gpt…
recovery gpt fail!
Trust Addr:0x4000, 0x58334c42
No find bl30.bin
No find bl32.bin
Load uboot, ReadLba = 2000
Load OK, addr=0x200000, size=0xd7838
RunBL31 0x40000 @ 166749 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
NOTICE: BL31: Rockchip release version: v1.1
INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2022.04-armbian (Aug 01 2022 - 01:23:50 +0000)
SoC: Rockchip rk3399
Reset cause: POR
Model: Radxa ROCK Pi 4C
DRAM: 3.9 GiB
Core: 275 devices, 28 uclasses, devicetree: separate
MMC: mmc@fe310000: 2, mmc@fe320000: 1, mmc@fe330000: 0
Loading Environment from SPIFlash… jedec_spi_nor flash@0: unrecognized JEDEC id bytes: ff, ff, ff
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@fe300000
starting USB…
Bus usb@fe380000: USB EHCI 1.00
Bus usb@fe3c0000: USB EHCI 1.00
Bus usb@fe800000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fe900000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@fe380000 for devices… 1 USB Device(s) found
scanning bus usb@fe3c0000 for devices… 1 USB Device(s) found
scanning bus usb@fe800000 for devices… 1 USB Device(s) found
scanning bus usb@fe900000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
3185 bytes read in 8 ms (388.7 KiB/s)
Executing script at 00500000
Boot script loaded from mmc 1
205 bytes read in 7 ms (28.3 KiB/s)
11356725 bytes read in 493 ms (22 MiB/s)
30540288 bytes read in 1309 ms (22.3 MiB/s)
76240 bytes read in 19 ms (3.8 MiB/s)
2698 bytes read in 15 ms (174.8 KiB/s)
Applying kernel provided DT fixup script (rockchip-fixup.scr)
Executing script at 09000000
Moving Image from 0x2080000 to 0x2200000, end=3fc0000
Loading init Ramdisk from Legacy Image at 06000000 …
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 11356661 Bytes = 10.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Loading Ramdisk to f143c000, end f1f109f5 … OK
Loading Device Tree to 00000000f13c1000, end 00000000f143bfff … OK
Starting kernel …
