on my Rock4B+ after I dd’ed the rock-pi-4b-plus_debian_bullseye_cli_b21.img.xz to the emmcblk0:
I get this CRC error also fsck errors with corrupt superblock.
During boot without SD inserted it waits very long on
Retrieving file: /boot/vmlinuz-5.10.110-8-rockchip
Retrieving file: /boot/initrd.img-5.10.110-8-rockchip
and then sucessfully loads kernel to login.
With SD inserted it’s directly loading.
Is this supposed to work like that as a fallback? Do I need to config the boot?
U-Boot latest-2023.04-3-fd4ed6b7-00060-g51d31fbc (Apr 27 2023 - 14:53:55 +0000)
SoC: Rockchip rk3399
Reset cause: POR
Model: Radxa ROCK Pi 4B+
DRAM: 2 GiB
PMIC: RK808
Core: 287 devices, 28 uclasses, devicetree: separate
MMC: mmc@fe310000: 2, mmc@fe320000: 1, mmc@fe330000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Unable to get mmc desc
Net: eth0: ethernet@fe300000
starting USB...
Bus usb@fe380000: ehci_generic usb@fe380000: Failed to get clocks (ret=-19)
Port not available.
Bus usb@fe3c0000: ehci_generic usb@fe3c0000: Failed to get clocks (ret=-19)
Port not available.
Bus usb@fe800000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus usb@fe900000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus usb@fe800000 for devices... 1 USB Device(s) found
scanning bus usb@fe900000 for devices... 1 USB Device(s) found
** Booting bootflow '[email protected]_2' with distro
U-Boot menu
1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
2: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip (rescue target)
Enter choice: 1: Debian GNU/Linux 11 (bullseye) 5.10.110-8-rockchip
append: root=UUID=36707237-6b57-4d7f-98a3-73b42dcf3822 quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty0 console=ttyFIQ0,1500000n8 console=ttyAML0,115200n8 console=ttyS2,1500000n8 console=ttyS0,1500000n8 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 plymouth.ignore-serial-consoles cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
Retrieving file: /usr/lib/linux-image-5.10.110-8-rockchip/rockchip/rk3399-rock-pi-4b-plus.dtb
Moving Image from 0x2080000 to 0x2200000, end=3d80000
## Flattened Device Tree blob at 01f00000
Booting using the fdt blob at 0x1f00000
Working FDT set to 1f00000
Loading Ramdisk to 7c718000, end 7cee0c25 ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0 flags=0)
Loading Device Tree to 000000007c6fe000, end 000000007c717ef5 ... OK
Working FDT set to 7c6fe000
CRC error stays the same with KDE image, waiting 60sec for kernel and ramdisk:
In: serial
Out: serial
Err: serial
starting USB...
Port not available.
Port not available.
USB XHCI 1.10
USB XHCI 1.10
U-Boot menu
same error with fsck:
rock@rock-pi-4b-plus:~$ sudo fsck /dev/mmcblk0
fsck from util-linux 2.36.1
e2fsck 1.46.2 (28-Feb-2021)
ext2fs_open2: Bad magic number in super-block
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/mmcblk0
The superblock could not be read or does not describe a valid ext2/ext3/ext4
filesystem. If the device is valid and it really contains an ext2/ext3/ext4
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 <device>
or
e2fsck -b 32768 <device>
Found a gpt partition table in /dev/mmcblk0
=> mmc info
Device: mmc@fe330000
Manufacturer ID: 88
OEM: 3
Bus Speed: 52000000
Mode: MMC High Speed (52MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 14.5 GiB
Bus Width: 8-bit
Erase Group Size: 512 KiB
HC WP Group Size: 4 MiB
User Capacity: 14.5 GiB WRREL
Boot Capacity: 4 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
=> mmc part
Partition Map for MMC device 0 -- Partition Type: EFI
Part Start LBA End LBA Name
Attributes
Type GUID
Partition GUID
1 0x00008000 0x0000ffff "config"
attrs: 0x0000000000000000
type: ebd0a0a2-b9e5-4433-87c0-68b6b72699c7
(data)
guid: 584cd271-82df-4087-8df6-23d6a127af07
2 0x00010000 0x01ce7fde "rootfs"
type: c12a7328-f81f-11d2-ba4b-00a0c93ec93b
(system)
guid: e3e4bd45-b846-43a0-9e68-773c8808c997
=> boot
** Booting bootflow ‘[email protected]_2’ with distro
U-Boot menu
with 30 sec waits and continuing like shown in my first post.
I have the same strange Superblock/GPT error on a microSD card which I fiddled on in u-boot and now the card says it’s writeprotected on every level.
Is it possible to put a SDcard in read-only in u-boot that it looks like hardware issue? (it’s a new card so not worn or so)
