Booting error, both nvme and SD card
I have previously had success booting the ubuntu server from nvme after flashing the SPI.
But then I tried armbian and flashed the with the new SPI with no success.
Now when I flash back to the previous SPI I get kernel errors when booting from both NVME and SD card.
I’m not sure how I can get the error logs when I boot.
So I took a picture and used image-to-text.
Error logs with DietPi image, but I have tried all other images aswell with similiar logs.
Should be noted when I tried the android image I got stuck on the “Rockchip” image at start.
Error logs below:
6.806632] mpp_rkudec2 fdc38100.rkudec-core: shared_niu_h is not found! 6.8066381 rkudec2_init: 1011: No niu hclk reset resource define
init:1008: No niu aclk reset resource define dec-core: shared_niu_a is not found!
6.807275] mpp_rkudec2 fdc48100.rkudec-core: shared_niu_a is not found! 6.8072821 rkudec2_init: 1008: No niu aclk reset resource define
6.8072891 mpp_rkudec2 fdc48100.rkudec-core: shared_niu_h is not found! 6.8072941 rkudec2_init: 1011: No niu hclk reset resource define
6.809557] mpp_iommu_probe: 405: failed to get device node 6.8095661 mpp_auidec auid-master: failed to attach iommu
7.0604681 rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy pll locked! 7.0607291 rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy lane locked! 7.3546671 rk806 spi2.0: no sleep-setting state
7.354717] rk806 spi2.0: no reset-setting pinctrl state 7.3547591 rk806 spi2.0: no dus-setting pinctrl state 7.6481171 kernel BUG at arch/arm64/kernel/traps.c:410! 7.6482511 Internal error: Oops
7.6491451 Modules linked in:
BUG: 0 [#1] SMP
7.649486] CPU: 4 PID: 0 Comm: swapper/4 Not tainted 5.10.110-rockchip-rk3588 #22.11.4 7.6503331 Hardware name: Radxa ROCK 5B (DT)
7.6508111 pstate: 00400009 (nzcu daif +PAN -UAO -TCO BTYPE—)
7.6514631 pc: do_undefinstr+0x17c/0x1e4
7.6519151 lr: do_undefinstr+0x94/0x1e4
7.6523531 sp : ffffffc0121f3d60
7.6527111 x29: ffffffc0121f3d60 x28: ffffff81008c8000
7.6532911 x27: 0000000000000000 x26: 0000000000000000
7.6538681 x25: 0000000000000000 x24: 0000000000000000 7.654446] x23: ffffffc011598dd8 x22: ffffffc0121f3de0 7.6550231 x21: 0000000000000000 x20: ffffffc011d0d730 7.6556001 x19: 00000000d50342df x18: 0000000000000000 7.656176] x17: 0000000000000043 x16: 0000000000000014 7.6567561 x15: 000000000000000a x14: 0000000000000000 7.6573281 x13: 0000000400000002 x12: 0000000100000002 7.6579041 x11: 0000000000000273 ×10: 0000000000000ad9 7.658480] x9: ffffffc010ff7e84 x8: ffffff81008c8b30 7.6590581 x7 : 0000000000000004 x6 : ffffff8104076480 7.659635] x5 : 0000000000000000 x4: 00000000d50342df 7.6602131 x3 : ffffffc011d0d798 x2 : 00000000dead4ead 7.6607901 x1 : 0000000000000004 XỨ : 0000000060-00009 7.661365] Call trace:
7.661644]
7.662055]
el1_undef+0x2c/0x48
el1_sync+0x84/0x140
arch_local_irq_disable+0x20/0x2c
7.662415] el1_sync_hand ler+0xac/0xb8
7.6628301
7.663190]
7.663658] do_idle+0x50/0x260
7.664002] cpu_startup_entry+0x2c/0x44
7.6644291 secondary_start_kernel+0x1b8/0x1e4
7.664921]
7.6649211 PC: 0xffffffc01001fc24:
7.665452] fa24 d5384102 f9400442 eb01005f 54ffff69 d50b7c21 52800001 17fffff7 d5384102 7.666355] fa44 f9400442 eb01005f 54fffe89 d50b7e21 52800001 17fffff0 d5384102 £9400442 7.667255] fa64 eb01005f 54fffda9 d50b7521 52800001 17ffffe9 f9408082 52800003 52800021 7.6681531 fa84 52800080 97ffff4b a8c17bfd d50323bf d65f03c0 d2800081 aa0403e0 97fffe41 7.669045] faa4 17fffffa aa1e03e9 d503201f d503233f a9bb7bfd 910003fd a90363f7 b000abd? 7.6742411 fac4 913762f7 f94002e1 f90027e1 d2800001 a90153f3 a9025bf5 aa0003f6 97ffdbZe 7.679485] fae4 34000360 a95002d5 f2400c1f 540003a0 d2800082 aa1503e1 910113e0 9406e09e 7.684763] fb04 b50008a0 b94047f3 d000e774 911cc294 91014280 943f608b aa1403e3 d2800015 7.690048] fb24 f8468c62 eb03005f 540007e1 aa0003e1 91014280 943f60cb b40006f5 2a1303e1 7.695356] fb44 aa1603e0 d63f02a0 35000660 £94027e1 f94002e0 ca000020 b40008c0 943f4912 7.7007141 fb64 36280420 d2800041 aa1503e0 97fffd98 b4000520 aa1503e0 52800014 97fffd4c 7.706164] fb84 aa0003f8 97fffd46 78400b13 97fffd40 35000434 12003e73 Za1303e0 940009bf 7.711667] fba4 72001c1f 54fffb20 91000ab5 d2800041 aa1503e0 97fffd86 b40002e0 aa1503e0 7.7172291 fbc4 97fffd3b aa0003f8 97fffd35 78400b15 97fffd2f 35000214 12003eb5 2a1342b3 7.722849] fbe4 17ffffca d2800081 aa1503e0 97fffd78 b4000120 aa1503e0 52800014 97fffd2c
Grab an emmc card writer and reader. Try it.
Dont have a eMMC available, seems to cost like 70$ where im from.
Just to make sure, After I have started into maskrom and entered below and click run.
Should I then be able to boot from SD card? or is there some other spi image?
I’m wondering since the wiki says its when you want to boot from nvme, but SD should still work right?
70$ is the 128gbs one if ure using the nvme just get the cheapeat one
well that dude dont know what it for people costs and why emmc is not a solution to ask for a person
just clean the spi first
and test it with a empty spi if you can boot from sd
and use a proper os then weird distros ,just use default or armbian to see if it works
Still cant get any OS to work, beside Debian from ( https://gitlab.collabora.com/hardware-enablement/rockchip-3588 )
Does anyone have any clues to why?
Aren’t their work pushed to mainline kernel?
Clear the SPI (using dd) and flash any memory card with armbian using dd or gnome-disks or rpi imager. It will work.
Hi, Thanks for the response.
Cleared the SPI using
rkdeveloptool db rk3588_spl_loader_v1.08.111.bin
rkdeveloptool wl 0 zero.img
rkdeveloptool rd
Cause no /dev/mtdblock* is found when its installed with debian.
So not sure what the dd command should look like.
Installed Armbian 23.02 Jammy from their page, Unfortunatly it did not work,
Either a stuck _ (underscore) in the upper corner or … [#1] SMP errors
Tried all kinds of operating system, the debian is the only one that works.
Hmmm
If it doesn’t detect /dev/mtdblock then it seems to me that there’s something wrong with the board - but I never tried Radxa debian. Maybe this is on purpose. But I also heard that some people bricked their services due to botched spi flashing.
Its not the debian from Rock5/downloads - Radxa Wiki
That doesn’'t work either, its this debian image
hardware-enablement / Rockchip RK3588 upstream enablement efforts / debian-image-recipes · GitLab (collabora.com)
This one is based on linux kernel 6.3
