Boot problem - hangs on line at bl31
I have a radxa0 that I installed LineageOS on, it worked fine. Asked for an update, when I saw it, it crashed and doesn’t start anymore.
It’s in Maskrom mode, I’ve tried u-boot.bin, radxa-erase-emmc.bin, among other procedures, and it doesn’t start, neither through SDcard nor eMMC.
in the console I verified that the initialization stops in the line “Run into bl31” according to the following log:
bl2_stage_init 0x81
hw id: 0x0001 - pwm id 0x00
bl2_stage_init 0xc0
bl2_stage_init 0x02
L0:00000000
L1:00000703
L2:00008067
L3:04000000
S1:00000000
B2:00002000
B1:e0f83180
TE: 136689
Board ID = 2
Set cpu clk to 24M
Set clk81 to 24M
CPU clk: 1200 MHz
Set clk81 to 166.6M
eMMC boot @ 0
sw8 s
board id: 2
Load FIP HDR from eMMC, src: 0x00010200, des: 0xfffd0000, size: 0x00004000, part: 0
fw parse done
Load ddrfw from eMMC, src: 0x00060200, des: 0xfffd0000, size: 0x0000c000, part: 0
Load ddrfw from eMMC, src: 0x00038200, des: 0xfffd0000, size: 0x00004000, part: 0
PIEI prepare done
fastboot data load
00000000
emmc switch 1 ok
00000000
emmc switch 2 ok
fastboot data verify
verify result: 265
LPDDR4 probe
ddr clk to 792MHz
Load ddrfw from eMMC, src: 0x0003c200, des: 0xfffd0000, size: 0x0000c000, part: 0
00000000
emmc switch 0 ok
dmc_version 0000
Check phy result
INFO : End of CA training
INFO : End of initialization
Check phy result
Check phy result
1D training succeed
Load ddrfw from eMMC, src: 0x00048200, des: 0xfffd0000, size: 0x0000c000, part: 0
Check phy result
channel==0
RxClkDly_Margin_A0==236 ps 12
TxDqDly_Margin_A0==236 ps 12
RxClkDly_Margin_A1==236 ps 12
TxDqDly_Margin_A1==236 ps 12
TrainedVREFDQ_A0==74
TrainedVREFDQ_A1==74
VrefDac_Margin_A0==24
DeviceVref_Margin_A0==40
VrefDac_Margin_A1==22
DeviceVref_Margin_A1==40
channel==1
RxClkDly_Margin_A0==216 ps 11
TxDqDly_Margin_A0==216 ps 11
TxDqDly_Margin_A1==216 ps 11
VrefDac_Margin_A0==22
VrefDac_Margin_A1==24
soc_vref_reg_value 0x 00000015 00000014 00000014 00000015 00000013 00000013 00000015 00000015 00000014 00000016 00000014 00000 013 00000013 00000015 00000014 00000015 00000015 00000015 00000014 00000016 00000016 00000014 00000017 00000015 00000017 00000 014 00000016 00000017 00000015 00000012 00000012 00000015 dram_vref_reg_value 0x 0000005e
2D training succeed
auto size-- 65535DDR cs0 size: 2048MB
DDR cs1 size: 2048MB
DMC_DDR_CTRL: 00e00024DDR size: 3928MB
cs0 DataBus test pass
cs1 DataBus test pass
cs0 AddrBus test pass
cs1 AddrBus test pass
100bdlr_step_size ps== 478
result report
00000000
emmc switch 3 ok
Authentication key not yet programmed
get rpmb counter error 0x00000007
00000000
emmc switch 0 ok
Load FIP HDR from eMMC, src: 0x00010200, des: 0x01700000, size: 0x00004000, part: 0
Load BL3X from eMMC, src: 0x0006c200, des: 0x0175c000, size: 0x000ec000, part: 0
0.0;M3 CHK:0;cm4_sp_mode 0
MVN_1=0x00000000
MVN_2=0x00000000
OPS=0x30
ring efuse init
28 0c 30 00 01 1d 29 00 00 01 35 38 37 43 46 50
[0.017150 Inits done]
secure task start!
high task start!
low task start!
run into bl31
After that, it stop and not change to USB storage or fastloader.
Can anyone help to solve this problem?
Please download the following loader and try again. We did some update to it a while ago:
https://dl.radxa.com/zero/images/loader/radxa-zero-erase-emmc.bin
I had already done this procedure and it also did not work. Stop at the same stage.
Your board might have hardware issue then. Please contact your original seller for RMA.
