I have been trying to power the Radxa Zero 3W through a board which powers the Radxa through the 5V GPIO pins. However, it does not seem to boot, the LED turns on and stays on. When the board is powered through the USB-C port, the OS boots and the LED starts blinking.
I think the board may be defaulting to booting off the eMMC storage (which I did not setup) when powered by the GPIO pins?
Any help would be much appreciated. Thank you!
Nick
Edit : Interesting behaviour. The Radxa won’t boot if I mount it on my board then plug in USB-C (no power from my board), the LED just stays on with no display output. However, if I plug in USB-C when it is unmounted, it boots just fine, and then if I mount the Radxa on my board after it is on, it functions just fine. So it can run mounted on my board, just can’t boot.
