Hello. I’m trying to install Armbian or Libreelec on the emmc, but despite the installation being successful, when I restart, I see the shell screen. With Ubuntu and Windows I have no problems. Can it be a problem with the Bios Uefi? If that’s it, how can I solve it? Thank you
Boot emmc problem
There is one bug that might give you troubles:
https://armbian.atlassian.net/browse/AR-1592
Boot from USB, then erase eMMC and then install …
Thanks Igor.Sorry,using the command fdisk, to me in the emmc remains a /dev/mmcblk2boot0 and /dev/mmcblk2boot1 and does not make me remove. when I install it tells me there is the boot of Ubuntu 2204,what I had before. And in fact after I get back the shell Thanks
I think you can ignore those two partitions. This is my working map:
cat /proc/partitions
major minor #blocks name
179 0 30310400 mmcblk0
179 1 30040047 mmcblk0p1
259 0 4096 mmcblk0p14
259 1 262144 mmcblk0p15
179 8 4096 mmcblk0boot0
179 16 4096 mmcblk0boot1
252 0 1967224 zram0
252 1 51200 zram1
Try perhaps creating same scheme. Partition 15 is EFI … which should be detected automatically, but installer also provides you to install there (this is bug), you need to have a root partition, where system goes.
