I have the Ubuntu from the Rock 5b downloads page installed on the eMMC module and armbian desktop on a sd card. So far have been able to boot both, but if both media is installed at the same time is there a default boot manager to control which is selected?
I see this on the Armbian docs, is a boot manager like this native on the rock 5b or is it something that has to do with armbian? I want to know the expected procedure when there are multiple boot devices.
This is screen from script that moves system to selected media and updates spi or boot partition if needed.
This donāt allow to choose drive on boot.
and yes - thatās armbian script inside booted OS
So what happens if there are multiple boot media present, is there a way to know which will be chosen between sd, emmc and m.2 ssd?
Now we canāt choose boot order
Boot priority is probably SPI ā eMMC ā SD, those are supported straight from factory on plain board (spi should be empty). If You flash spi with u-boot - You will also get boot script with own boot sequence and maybe nvme and usb support (in future maybe network boot). Then it depends on SPI contents.
The UEFI/EDK2 bootloader available in another thread here has a boot menu, but for now, itās only accessible via serial console, not on screen, because HDMI support is still being worked on.
I multi-boot by simply changing the uuid in armbianEnv.txt or extlinux.conf I will try the efi/edk2 image when hdmi is working.
After flashing the SPI using the files from https://wiki.radxa.com/Rock5/install/spi, (rk3588_spl_loader_v1.08.111.bin and rock-5b-spi-image-g49da44e116d.img) I installed the Ubuntu server image on an SD card, eMMC and M.2 SSD. What I found was that the priority was SD Card, eMMC, M.2 SSD. Ran through all my testing here: https://www.learningtopi.com/sbc/radxa-rock-5b-setup/
The device boots from SD first and from eMMC later. You can therefore ādual bootā by having one OS on the eMMC and another (more āvolatileā) on an SD card.
Great nice read! So changing the SPI is booting first from the NVME and when putting a bootable SD with OS itās booting from the SD card?
