I have buy module A8(RTL8821BE) for my Rock5B.
However, it is not working when I try to scan use Bluetooth
I tried to follow the Github to update the driver but still not work.
Is it any way to fix it?
Have you tried
bluetoothctl
command instead and scan/pair it that way. Those GUI applications are sometimes rubbish.
I have two Rcok5 with A8 WIFI/BT wireless card.
They are 20cm from each other.
Both devices recognise the A8 cards. Wifi works.
I have blacklisted the suggested modules.
lsusb shows the BT modules
admin@rock-5b-001:~$ lsusb
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 002: ID 154b:005b PNY Flash Drive
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 0bda:b85b Realtek Semiconductor Corp. Bluetooth Radio
Bus 001 Device 003: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
bluetoothctl sees the device
admin@rock-5b-001:~$ sudo bluetoothctl list
Controller 2C:05:47:78:DE:8B rock-5b-001 [default]
admin@rock-5b-001:~$ sudo bluetoothctl show
Controller 2C:05:47:78:DE:8B (public)
Alias: rock-5b-001
Class: 0x00000000
Powered: yes
Discoverable: no
DiscoverableTimeout: 0x000000b4
Pairable: no
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d0542
Discovering: no
Roles: central
Roles: peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x0a (10)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
SupportedSecondaryChannels: 1M
SupportedSecondaryChannels: 2M
SupportedSecondaryChannels: Coded
Yet, when I set one of the device in discoverable mode and try to do a scan from the other one, it does not find anything.
Same if I try to discover it from my phone or try to get my phone discovered.
Any suggestions ?
