Hello
I am having Rockpi 4 B and C both the boards. On both the boards with Debian Images bluetooth is not working. There is not adapter for the BLE and not able to start the scan even power up also not working.
If I use the Ubuntu on the the boards it works well. For my further task I need Debian with working bluetooth.
I have tried all the possible ways but no luck.
Can you please help?
root@linaro-alip:/home/linaro# hciconfig
hci0: Type: Primary Bus: UART
BD Address: 43:45:C5:00:1F:AC ACL MTU: 1021:8 SCO MTU: 64:1
UP RUNNING
RX bytes:897 acl:0 sco:0 events:65 errors:0
TX bytes:5288 acl:0 sco:0 commands:65 errors:0
> root@linaro-alip:/home/linaro# pulseaudio --start
> W: [pulseaudio] main.c: This program is not intended to be run as root (unless --system is specified).
Bluetooth is not turning to discoverable and also not scanning.
root@linaro-alip:/home/linaro# bluetoothctl
[NEW] Controller 43:45:C5:00:1F:AC linaro-alip [default]
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# discoverable on
[bluetooth]# pairable on
Changing pairable on succeeded
[bluetooth]# agent on
Agent registered
Failed to set discoverable on: org.freedesktop.DBus.Error.NoReply
[bluetooth]# default-agent
Default agent request successful
[bluetooth]# scan on
Discovery started
[bluetooth]#
