On new setup bluetoothctl is not able to discover the devices. Below is terminal result, no list of devices.
root@linaro-alip:/home/linaro# bluetoothctl
[NEW] Controller 43:45:C5:00:1F:AC linaro-alip [default]
[bluetooth]# default-agent
No agent is registered
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# scan on
Discovery started
[bluetooth]#
Below is the bluetooth status
root@linaro-alip:/home/linaro# systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2021-03-03 14:48:14 UTC; 13min ago
Docs: man:bluetoothd(8)
Main PID: 795 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4915)
CGroup: /system.slice/bluetooth.service
└─795 /usr/lib/bluetooth/bluetoothd
Mar 03 14:48:14 linaro-alip bluetoothd[795]: Bluetooth daemon 5.43
Mar 03 14:48:14 linaro-alip bluetoothd[795]: Starting SDP server
Mar 03 14:48:15 linaro-alip bluetoothd[795]: kernel lacks bnep-protocol support
Mar 03 14:48:15 linaro-alip bluetoothd[795]: System does not support network plugin
Mar 03 14:48:15 linaro-alip bluetoothd[795]: Bluetooth management interface 1.10 initialized
Mar 03 14:48:15 linaro-alip bluetoothd[795]: Failed to obtain handles for "Service Changed" characteristic
Mar 03 14:48:15 linaro-alip bluetoothd[795]: Sap driver initialization failed.
Mar 03 14:48:15 linaro-alip bluetoothd[795]: sap-server: Operation not permitted (1)
Mar 03 14:48:21 linaro-alip bluetoothd[795]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource
Mar 03 14:48:21 linaro-alip bluetoothd[795]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink
I checked the suggested thread but no luck and I have not tried the dmesg. Just for the test, I tried Ubuntu Server 20.04 image on the same 4C devices and bluetooth worked perfectly. See below images.
@jack
You have really knowledge about Linux or ROCK Pi, You don’t know what happening with your products rockpi 4b and C it’s not working give trouble to the user, First authenticate the answer then replay don’t come on a forum like Gibberish people Facing this idiot issue last 1-2 month. This is a frustrating China board and Chinese people.
This issue is still not solved correctly by Radxa.
Bluetooth is only working with the server image via cli…. Debian desktop or installing an Ubuntu desktop on the Ubuntu server image breaks Bluetooth.
@jack the quality of images is going downhill… How can you hope to keep selling products with basic functionally not working ? Bluetooth is not an advanced feature.
Could you guys release a desktop image for the Rock Pi 4C that has Bluetooth actually working?
