I tried to test the TI SensorTag with the LightBlue app, but it was not able to scan.
Is BLE not working on Android 9?
When I turned on location, I was able to scan it.
However, when I try to connect, I get an error 133.
2020-09-07 19:37:59.801 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(948)] GATT_Register 0d2a284f-1999-64ae-1497-f79ca3bc3064
2020-09-07 19:37:59.801 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(968)] allocated gatt_if=5
2020-09-07 19:39:11.128 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(948)] GATT_Register 60b5bab6-2ff8-1f33-2221-5076b7c676c9
2020-09-07 19:39:11.128 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(968)] allocated gatt_if=5
2020-09-07 19:39:24.844 3743-3743/no.nordicsemi.android.mcp D/BluetoothGatt: connect() - device: 54:6C:0E:80:87:83, auto: false
2020-09-07 19:39:24.844 3743-3743/no.nordicsemi.android.mcp D/BluetoothGatt: registerApp()
2020-09-07 19:39:24.844 3743-3743/no.nordicsemi.android.mcp D/BluetoothGatt: registerApp() - UUID=4565437d-7df5-4c5a-b35d-3d315a1dab9a
2020-09-07 19:39:24.848 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(948)] GATT_Register 3a0acb7d-8e06-811c-5d4b-517e5df381f2
2020-09-07 19:39:24.848 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(968)] allocated gatt_if=5
2020-09-07 19:39:24.849 3743-3755/no.nordicsemi.android.mcp D/BluetoothGatt: onClientRegistered() - status=0 clientIf=5
2020-09-07 19:39:24.852 586-968/com.android.bluetooth I/bt_stack: [INFO:gatt_api.cc(1109)] GATT_Connectgatt_if=5 54:6c:0e:80:87:83
2020-09-07 19:39:54.853 586-968/com.android.bluetooth W/bt_stack: [WARNING:bta_gattc_act.cc(1040)] bta_gattc_conn_cback: cif=3 connected=0 conn_id=0x0003 reason=0x0100
2020-09-07 19:39:54.853 586-968/com.android.bluetooth W/bt_stack: [WARNING:bta_gattc_act.cc(1040)] bta_gattc_conn_cback: cif=4 connected=0 conn_id=0x0004 reason=0x0100
2020-09-07 19:39:54.854 586-968/com.android.bluetooth W/bt_stack: [WARNING:bta_gattc_act.cc(1040)] bta_gattc_conn_cback: cif=5 connected=0 conn_id=0x0005 reason=0x0100
2020-09-07 19:39:54.854 586-968/com.android.bluetooth W/bt_stack: [WARNING:bta_gattc_act.cc(339)] bta_gattc_open_fail: Cannot establish Connection. conn_id=0. Return GATT_ERROR(133)
2020-09-07 19:39:54.858 3743-3755/no.nordicsemi.android.mcp D/BluetoothGatt: onClientConnectionState() - status=133 clientIf=5 device=54:6C:0E:80:87:83
I’ve analyzed the HCI snoop log for BLE in WireShark.
Is it possible that this is not being successfully notified by the device after Create Connection?
1037 14.774880 host controller HCI_CMD 29 Sent LE Create Connection
1038 14.776644 controller host HCI_EVT 7 Rcvd Command Status (LE Create Connection)
1039 14.949549 controller host HCI_EVT 34 Rcvd LE Meta (LE Enhanced Connection Complete)
1040 15.949521 controller host HCI_EVT 7 Rcvd Disconnect Complete
1041 44.775156 host controller HCI_CMD 4 Sent LE Create Connection Cancel
1042 44.777801 controller host HCI_EVT 7 Rcvd Command Complete (LE Create Connection Cancel)
It connected well with Android 10.
What’s the difference?
I’m starting to focus on that now.
https://github.com/NordicSemiconductor/Android-BLE-Library/issues/53,
This could be an android9 stack error.
You can try to do all your BLE operations on UIThread.
Thank you.
I’m currently considering using Android 10, which is working properly.
If I ever get it running on Android 9, I’ll give it a try.
