ryann
August 6, 2024, 9:00am
1
Greetings. Today we are pleased to release BIOS version V001 for Radxa X4.
Main Features
Supports CPU PL1 and PL2 customization and performance related settings
Improve memory compatibility, support 4/8/12GB memory
Supports RTC timed wake-up
2.5G wired network support POE, PXE, WOL function.
Support software or hardware reset RP2040 to bootsel
More detailed documentation refer to https://docs.radxa.com/en/x/x4
BIOS update tools at https://docs.radxa.com/en/x/x4/bios/update-bios
Is it possible to enable In-band ECC support in the BIOS of the Radxa X4?
I have read a few guides and it seems the board suffers from high temperatures meaning that the current case/fan options dont do its justice. I feel this is crtitic.. Do you guys have been trough the same ? Will there be an solution?
Guess this was the wildest ive seen.
opened 03:09AM - 20 Jul 24 UTC
testing complete
## Basic information
- Board URL (official): https://radxa.com/products/x/x4 ([docs](https://docs.radxa.com/en/x/x4))
- Board purchased from: Arace
- Board purchase date: July 19, 2024
- Board specs (as tested): 8GB
- Board price (as tested): $79.90 (+ $14.90 heatsink+fan)
## Linux/system information
# output of `screenfetch`
./+o+- jgeerling@radxa-x4
yyyyy- -yyyyyy+ OS: Ubuntu 24.04 noble
://+//////-yyyyyyo Kernel: x86_64 Linux 6.8.0-39-generic
.++ .:/++++++/-.+sss/` Uptime: 3m
.:++o: /++++++++/:--:/- Packages: 1594
o:+o+:++.`..```.-/oo+++++/ Shell: bash 5.2.21
.:+o:+o/. `+sssoo+/ Disk: 9.3G / 938G (2%)
.++/+:+oo+o:` /sssooo. CPU: Intel N100 @ 4x 3.4GHz [49.0°C]
/+++//+:`oo+o /::--:. GPU: UHD Graphics
\+/+o+++`o++o ++////. RAM: 1399MiB / 7716MiB
.++.o+++oo+:` /dddhhh.
.+.o+oo:. `oddhhhh+
\+.++o+o``-````.:ohdhhhhh+
`:o+++ `ohhhhhhhhyo++os:
.o:`.syhhhhhhh/.oo++o`
/osyyyyyyo++ooo+++/
````` +oo+++o\:
`oo++.
# output of `uname -a`
Linux radxa-x4 6.8.0-39-generic #39-Ubuntu SMP PREEMPT_DYNAMIC Fri Jul 5 21:49:14 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
## Benchmark results
### CPU
- Geekbench 6: (1185 single / 2658 multi - https://browser.geekbench.com/v6/cpu/7127802)
- 37.224 Gflops at 2.33 Gflops/W ([geerlingguy/top500-benchmark](https://github.com/geerlingguy/top500-benchmark) [HPL result](https://github.com/geerlingguy/top500-benchmark/issues/38))
### Power
- Idle power draw (at wall): 9.1 W
- Maximum simulated power draw (`stress-ng --matrix 0`): 18.5 W
- During Geekbench multicore benchmark: 21.2 W
- During `top500` HPL benchmark: 16 W
### Disk
#### Kioxia BG6 2230 1TB NVMe SSD (KBG40ZNS1T02)
[comment]: # (Run `lsblk -o NAME,FSTYPE,LABEL,MOUNTPOINT,SIZE,MODEL` to get model)
| Benchmark | Result |
| iozone 4K random read | 60.17 MB/s |
| iozone 4K random write | 227.78 MB/s |
| iozone 1M random read | 1679.58 MB/s |
| iozone 1M random write | 1506.50 MB/s |
| iozone 1M sequential read | 1701.32 MB/s |
| iozone 1M sequential write | 1527.16 MB/s |
wget https://raw.githubusercontent.com/geerlingguy/pi-cluster/master/benchmarks/disk-benchmark.sh
chmod +x disk-benchmark.sh
sudo MOUNT_PATH=/ TEST_SIZE=1g ./disk-benchmark.sh
Run benchmark on any attached storage device (e.g. eMMC, microSD, NVMe, SATA) and add results under an additional heading.
Also consider running [PiBenchmarks.com script](https://www.jeffgeerling.com/blog/2023/using-pibenchmarkscom-sbc-disk-performance-testing).
### Network
`iperf3` results:
#### Built-in 2.5 Gbps Ethernet (Intel I226-V)
- `iperf3 -c $SERVER_IP`: 2.35 Gbps
- `iperf3 -c $SERVER_IP --reverse`: 1.77 Gbps
- `iperf3 -c $SERVER_IP --bidir`: 2.34 Gbps up, 1.77 Gbps down
#### Built-in Realtek WiFi 6 (RTL8852BE)
- `iperf3 -c $SERVER_IP`: 651 Mbps
- `iperf3 -c $SERVER_IP --reverse`: 319 Mbps
- `iperf3 -c $SERVER_IP --bidir`: 596 Mbps up, 88 Mbps down
## GPU
`glmark2-es2` results:
glmark2 2023.01
OpenGL Information
GL_VENDOR: Intel
GL_RENDERER: Mesa Intel(R) Graphics (ADL-N)
GL_VERSION: OpenGL ES 3.2 Mesa 24.0.9-0ubuntu0.1
Surface Config: buf=32 r=8 g=8 b=8 a=8 depth=24 stencil=0 samples=0
Surface Size: 800x600 windowed
[build] use-vbo=false: FPS: 2512 FrameTime: 0.398 ms
[build] use-vbo=true: FPS: 2623 FrameTime: 0.381 ms
[texture] texture-filter=nearest: FPS: 2532 FrameTime: 0.395 ms
[texture] texture-filter=linear: FPS: 2495 FrameTime: 0.401 ms
[texture] texture-filter=mipmap: FPS: 2507 FrameTime: 0.399 ms
[shading] shading=gouraud: FPS: 1958 FrameTime: 0.511 ms
[shading] shading=blinn-phong-inf: FPS: 1939 FrameTime: 0.516 ms
[shading] shading=phong: FPS: 3638 FrameTime: 0.275 ms
[shading] shading=cel: FPS: 3646 FrameTime: 0.274 ms
[bump] bump-render=high-poly: FPS: 2344 FrameTime: 0.427 ms
[bump] bump-render=normals: FPS: 4118 FrameTime: 0.243 ms
[bump] bump-render=height: FPS: 2491 FrameTime: 0.402 ms
[effect2d] kernel=0,1,0;1,-4,1;0,1,0;: FPS: 2842 FrameTime: 0.352 ms
[effect2d] kernel=1,1,1,1,1;1,1,1,1,1;1,1,1,1,1;: FPS: 1348 FrameTime: 0.742 ms
[pulsar] light=false:quads=5:texture=false: FPS: 4415 FrameTime: 0.227 ms
[desktop] blur-radius=5:effect=blur:passes=1:separable=true:windows=4: FPS: 1216 FrameTime: 0.823 ms
[desktop] effect=shadow:windows=4: FPS: 2335 FrameTime: 0.428 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 655 FrameTime: 1.528 ms
[buffer] columns=200:interleave=false:update-dispersion=0.9:update-fraction=0.5:update-method=subdata: FPS: 1187 FrameTime: 0.843 ms
[buffer] columns=200:interleave=true:update-dispersion=0.9:update-fraction=0.5:update-method=map: FPS: 621 FrameTime: 1.610 ms
[ideas] speed=duration: FPS: 2410 FrameTime: 0.415 ms
[jellyfish] <default>: FPS: 2134 FrameTime: 0.469 ms
[terrain] <default>: FPS: 204 FrameTime: 4.914 ms
[shadow] <default>: FPS: 3225 FrameTime: 0.310 ms
[refract] <default>: FPS: 508 FrameTime: 1.969 ms
[conditionals] fragment-steps=0:vertex-steps=0: FPS: 3842 FrameTime: 0.260 ms
[conditionals] fragment-steps=5:vertex-steps=0: FPS: 3708 FrameTime: 0.270 ms
[conditionals] fragment-steps=0:vertex-steps=5: FPS: 3697 FrameTime: 0.271 ms
[function] fragment-complexity=low:fragment-steps=5: FPS: 3447 FrameTime: 0.290 ms
[function] fragment-complexity=medium:fragment-steps=5: FPS: 3307 FrameTime: 0.302 ms
[loop] fragment-loop=false:fragment-steps=5:vertex-steps=5: FPS: 3047 FrameTime: 0.328 ms
[loop] fragment-steps=5:fragment-uniform=false:vertex-steps=5: FPS: 3273 FrameTime: 0.306 ms
[loop] fragment-steps=5:fragment-uniform=true:vertex-steps=5: FPS: 3566 FrameTime: 0.280 ms
glmark2 Score: 2538
Note: This benchmark requires an active display on the device. Not all devices may be able to run `glmark2-es2`, so in that case, make a note and move on!
TODO: See [this issue](https://github.com/geerlingguy/sbc-reviews/issues/2) for discussion about a full suite of standardized GPU benchmarks.
## Memory
`tinymembench` results:
<details>
<summary>Click to expand memory benchmark result</summary>
tinymembench v0.4.10 (simple benchmark for memory throughput and latency)
== Memory bandwidth tests ==
== Note 1: 1MB = 1000000 bytes ==
== Note 2: Results for 'copy' tests show how many bytes can be ==
== copied per second (adding together read and writen ==
== bytes would have provided twice higher numbers) ==
== Note 3: 2-pass copy means that we are using a small temporary buffer ==
== to first fetch data into it, and only then write it to the ==
== destination (source -> L1 cache, L1 cache -> destination) ==
== Note 4: If sample standard deviation exceeds 0.1%, it is shown in ==
== brackets ==
C copy backwards : 5373.3 MB/s (0.2%)
C copy backwards (32 byte blocks) : 5372.2 MB/s
C copy backwards (64 byte blocks) : 5372.9 MB/s
C copy : 5456.5 MB/s
C copy prefetched (32 bytes step) : 4020.8 MB/s
C copy prefetched (64 bytes step) : 4143.6 MB/s (0.2%)
C 2-pass copy : 5217.0 MB/s (0.1%)
C 2-pass copy prefetched (32 bytes step) : 3174.1 MB/s
C 2-pass copy prefetched (64 bytes step) : 3175.5 MB/s (0.1%)
C fill : 7946.8 MB/s
C fill (shuffle within 16 byte blocks) : 7943.5 MB/s
C fill (shuffle within 32 byte blocks) : 7946.5 MB/s
C fill (shuffle within 64 byte blocks) : 7944.3 MB/s (0.2%)
standard memcpy : 8138.6 MB/s
standard memset : 7968.4 MB/s
MOVSB copy : 5436.5 MB/s
MOVSD copy : 5275.4 MB/s (2.6%)
SSE2 copy : 4847.0 MB/s
SSE2 nontemporal copy : 7660.0 MB/s (0.8%)
SSE2 copy prefetched (32 bytes step) : 4677.2 MB/s (0.3%)
SSE2 copy prefetched (64 bytes step) : 4690.3 MB/s (0.2%)
SSE2 nontemporal copy prefetched (32 bytes step) : 6329.2 MB/s (0.3%)
SSE2 nontemporal copy prefetched (64 bytes step) : 6597.4 MB/s
SSE2 2-pass copy : 4644.6 MB/s (1.5%)
SSE2 2-pass copy prefetched (32 bytes step) : 3697.0 MB/s (0.7%)
SSE2 2-pass copy prefetched (64 bytes step) : 3767.6 MB/s
SSE2 2-pass nontemporal copy : 2722.4 MB/s (1.2%)
SSE2 fill : 7329.0 MB/s (0.5%)
SSE2 nontemporal fill : 16293.2 MB/s
== Memory latency test ==
== Average time is measured for random memory accesses in the buffers ==
== of different sizes. The larger is the buffer, the more significant ==
== are relative contributions of TLB, L1/L2 cache misses and SDRAM ==
== accesses. For extremely large buffer sizes we are expecting to see ==
== page table walk with several requests to SDRAM for almost every ==
== memory access (though 64MiB is not nearly large enough to experience ==
== this effect to its fullest). ==
== Note 1: All the numbers are representing extra time, which needs to ==
== be added to L1 cache latency. The cycle timings for L1 cache ==
== latency can be usually found in the processor documentation. ==
== Note 2: Dual random read means that we are simultaneously performing ==
== two independent memory accesses at a time. In the case if ==
== the memory subsystem can't handle multiple outstanding ==
== requests, dual random read has the same timings as two ==
== single reads performed one after another. ==
block size : single random read / dual random read, [MADV_NOHUGEPAGE]
1024 : 0.0 ns / 0.0 ns
2048 : 0.0 ns / 0.0 ns
4096 : 0.0 ns / 0.0 ns
8192 : 0.0 ns / 0.0 ns
16384 : 0.0 ns / 0.0 ns
32768 : 0.0 ns / 0.0 ns
65536 : 2.5 ns / 3.7 ns
131072 : 3.8 ns / 4.7 ns
262144 : 5.1 ns / 6.0 ns
524288 : 6.4 ns / 7.2 ns
1048576 : 7.1 ns / 7.5 ns
2097152 : 8.7 ns / 9.8 ns
4194304 : 14.9 ns / 18.8 ns
8388608 : 34.2 ns / 50.9 ns
16777216 : 89.3 ns / 129.8 ns
33554432 : 125.3 ns / 165.9 ns
67108864 : 145.4 ns / 181.9 ns
block size : single random read / dual random read, [MADV_HUGEPAGE]
262144 : 4.4 ns / 4.9 ns
524288 : 4.7 ns / 5.0 ns
1048576 : 4.9 ns / 5.0 ns
2097152 : 5.2 ns / 5.3 ns
4194304 : 11.3 ns / 14.4 ns
8388608 : 28.9 ns / 43.7 ns
16777216 : 80.1 ns / 114.8 ns
33554432 : 109.6 ns / 140.2 ns
67108864 : 125.3 ns / 148.9 n
</details>
## `sbc-bench` results
https://0x0.st/XO8j.bin
* memcpy: 7292.7 MB/s, memchr: 10791.5 MB/s, memset: 7153.0 MB/s
* 16M latency: 145.3 126.3 146.2 126.9 145.9 126.7 119.4 126.5
* 128M latency: 160.6 144.3 162.0 144.5 161.0 171.1 139.2 141.3
* 7-zip MIPS (3 consecutive runs): 7919, 7956, 7971 (7950 avg), single-threaded: 3459
* `aes-256-cbc 891938.02k 1178187.61k 1216253.87k 1227214.51k 1230935.38k 1230744.23k`
* `aes-256-cbc 876402.26k 1132943.79k 1217788.42k 1228350.12k 1230916.27k 1230236.33k`
## Phoronix Test Suite
Results from [pi-general-benchmark.sh](https://gist.github.com/geerlingguy/570e13f4f81a40a5395688667b1f79af):
- pts/encode-mp3: 9.461 sec
- pts/x264 4K: 4.43 fps
- pts/x264 1080p: 20.22 fps
- pts/phpbench: 706245
- pts/build-linux-kernel (defconfig): 1018.833 sec
ryann
August 13, 2024, 1:29am
5
The X4 was verified with our case.
With default BIOS, aida64 running fpu, the cpu stabilized at around 60 degrees.
With CPU TDP PL1 not limited, cpu temps are around 90 degrees.
The key point is that the cpu and the heat sink should have good contact and the thermal conductivity of the silicone should be higher than 11W/ (m-K).
Anyway, x86 needs better Thermal Solutions than arm.
based on my test results I can confirm the same results as you’ve stated ryan 62 degrees at full max load. 33-36 at idle
ryann
August 23, 2024, 7:10am
7
Great. thanks for your confirm
I have a new RADXA X4 with 64GB emmc on board.
But I’m not able to boot from this storage. In your help you have a option to
auto enable it ( Advanced->SDIO Configuration).
You have made this help with an older bios version.
With this new Version I do not see this option.
So for me the emmc is useless when I cannot boot form it…
ryann
August 29, 2024, 9:14am
9
Hello friend
The emmc for X4 is always available
In the latest BIOS, we also can see the emmc list at Advanced->SDIO configuration
And we can install windows/linux both into emmc and bootup
Can you confirm the BIOS version you saw in the BIOS? and follow the docs to install the system into emmc
Hi Ryann,
thank’s for your fast response. Now I tried to install Ubuntu this works fine. But when I try to install my custom OS (barebox + linux) I can’t see the EFI boot device. When do you show the boot device? What do you expect? When I do the same on a Intel NUC device or a LivaQ2 device i can boot my image?
this is my fdisk -l output
Disk /dev/mmcblk0: 58 GB, 62537072640 bytes, 122142720 sectors
1908480 cylinders, 4 heads, 16 sectors/track
Units: sectors of 1 * 512 = 512 bytes
Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type
/dev/mmcblk0p1 * 128,0,1 447,3,16 8192 28671 20480 10.0M ef EFI (FAT-12/16/32)
/dev/mmcblk0p2 768,0,1 1023,3,16 49152 10534911 10485760 5120M 83 Linux
/dev/mmcblk0p3 1023,3,16 1023,3,16 10534912 21020671 10485760 5120M 83 Linux
/dev/mmcblk0p4 1023,3,16 1023,3,16 21020672 122142719 101122048 48.2G 83 Linux
Disk /dev/mmcblk0boot0: 4 MB, 4194304 bytes, 8192 sectors
128 cylinders, 4 heads, 16 sectors/track
and this is on the EFI partition
root@foo:~ ll /mnt/
drwxr-xr-x 4 root root 16384 Jan 1 1970 .
drwxr-xr-x 20 root root 4096 Dec 1 00:00 …
drwxr-xr-x 4 root root 2048 Dec 1 00:00 EFI
drwxr-xr-x 2 root root 2048 Dec 1 00:00 network-drivers
root@foo:~ ll /mnt/EFI/
drwxr-xr-x 4 root root 2048 Dec 1 00:00 .
drwxr-xr-x 4 root root 16384 Jan 1 1970 …
drwxr-xr-x 2 root root 2048 Dec 1 00:00 BAREBOX
drwxr-xr-x 2 root root 2048 Dec 1 00:00 BOOT
root@foo:~ ll /mnt/EFI/BAREBOX/
drwxr-xr-x 2 root root 2048 Dec 1 00:00 .
drwxr-xr-x 4 root root 2048 Dec 1 00:00 …
-rwxr-xr-x 1 root root 1369 Dec 1 00:00 state.dtb
root@foo:~ ll /mnt/EFI/BOOT/
-rwxr-xr-x 1 root root 590090 Dec 1 00:00 BOOTx64.EFI
ryann
August 30, 2024, 2:21am
11
Please try extended EFI partition to 100MB, we have previously encountered the problem that the efi partition is less than 100MB and cannot be boot
Kinsman
December 3, 2024, 11:42am
12
On checking the BIOS update page for the X4 today, I notice that downloading the firmware now gives a version of V002 - is there a changelog anywhere that details what’s new in this version?
ryann
December 4, 2024, 1:31am
13
V002 just added support for 16GB memory, no other update.
