I’m running the Armbian “rolling release” 25.04 “Plucky” from the very end of https://www.armbian.com/radxa-rock-5-itx/ on NVM and it’s been rock solid so far (at least after switching to the “edge” upstream kernel (currently 6.14.0-rc4).
I’m running a 256 GB Samsung NVME drive with the OS in the main m.2 socket, a 2-port SATA controller in the A/E m.2 socket, and running 2 SSDs and 4 HDDs on the resulting 6 SATA ports.
With the mainline kernel graphics support is very basic (FHD 60 Hz or 4K 30 Hz on only one HDMI output), and things like the NPU aren’t available AFAIU, but it works perfectly so far for my NAS + Home Assistant needs. With mainline I all the devices are seen in all the boots (no randomly disappearing SATA controller).
I installed the image on an micro-SD card and booted from it in order to install onto the NVME.
From the SD card boot environment I did the following:
Update the system on SD and switch it to the edge mainline kernel via armbian-config.
Copy the first 16 MB of the SD device to the SPI nor via dd so the bootloader is there.
Download the same armbian image again into the SD free space and dd it onto the NVME so armbian is installed there.
After removing the SD and rebooting to NVME, switched to mainline kernel there again via armbian-config.
I recently installed the “Server images with Armbian Linux v6.12” (Ubuntu Nobel) that is now linked from https://www.armbian.com/radxa-rock-5-itx/ and I have not had any SATA issues since. The 6.1.99 vendor kernels still have intermittent SATA for me. I do not get any video at all on either HDMI port, but since I’m running as a server it does not really impact me.
Current uname:
Linux alcatraz 6.12.20-current-rockchip64 #2 SMP PREEMPT Sat Mar 22 19:54:28 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
