Armbian, image glitch
There are no Armbian images. Which means you are on your own fixing the problems.
@igorp Index of /zero/images/armbian
That is not official Armbian.
They come from: Download - Armbian
Ok. But this is the firmware from the developer.
So I wrote about the error here.
@FOX the issue is related to the display driver. Anything rather 1920 1080p does produce glitches. @jack
Full HD same https://photos.app.goo.gl/n7jQwTVmA5x2HJDQ8
[  353.593055] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x3929f80, tail=0x3929f80
[  353.597367] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7301, status=0x58, head=0x3929f80, tail=0x3929f80, sched_job=00000000259b3ee8
[  353.611825] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x6c80b80, tail=0x6c80b80
[  353.620157] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x58, head=0x6c80b80, tail=0x6c80b80, sched_job=000000000d22c7dd
[  353.668782] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x9eebb80, tail=0x9eebb80
[  353.673516] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7301, status=0x58, head=0x9eebb80, tail=0x9eebb80, sched_job=00000000ed7f3da3
[  353.695429] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x39eab80, tail=0x39eab80
[  353.699737] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x58, head=0x39eab80, tail=0x39eab80, sched_job=000000008afe61d9
[  353.864162] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x48a4380, tail=0x48a4380
[  353.868889] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x58, head=0x48a4380, tail=0x48a4380, sched_job=00000000d7645784
[  353.899062] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x5518380, tail=0x5518380
[  353.903831] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7301, status=0x58, head=0x5518380, tail=0x5518380, sched_job=000000007fd8199f
[  353.941902] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x75b9380, tail=0x75b9380
[  353.946561] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7301, status=0x58, head=0x75b9380, tail=0x75b9380, sched_job=0000000046ff4c79
[  354.039957] panfrost ffe40000.gpu: js fault, js=0, status=UNKNOWN, head=0x690a380, tail=0x690a380
[  354.043350] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x5b, head=0x690a380, tail=0x690a380, sched_job=000000005251cb9c
[  354.070878] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x43ca380, tail=0x43ca380
[  354.075230] panfrost ffe40000.gpu: gpu sched timeout, js=0, config=0x7300, status=0x58, head=0x43ca380, tail=0x43ca380, sched_job=000000005251cb9c
[  354.120595] panfrost ffe40000.gpu: js fault, js=0, status=DATA_INVALID_FAULT, head=0x61e6380, tail=0x61e6380
Ohh, that’s a panfrost issue! What version of the drover are you utilizing?? Try main mesa. I have no problems with main.
on ubuntu is easy to upgrade mesa bc of oibaf launchpad repos.. but on debian, you will most probably had to compile it yourself :frowning:
do you know which packages/libraries need to be compiled ourselves in this case? Thanks.
I have the same issue with the latest RSDK image for Radxa Zero. When the error appears in the kernel log, the image freezes for a few seconds.
Is there some solution except of completely disabling Panfrost driver? Or some driver alternative to have GPU acceleration active (I need GL rendering in my application and blacklisting Panfrost results in reduced FPS).
