Armbian does not support A2 WIFI module
I am trying to make it work with armbian desktop. The device works fine with radxa debian, ubuntu, android.
lshw -short shows (I dont have eMMC attached, booting from microsd)
/0/0 bridge RK3588
/0/0/0 enP4p65s0 network RTL8125 2.5GbE Controller
/1 usb1 bus EHCI Host Controller
/1/1 bus USB 2.0 Hub
/2 usb2 bus EHCI Host Controller
/3 usb3 bus Generic Platform OHCI controller
/4 usb4 bus Generic Platform OHCI controller
/5 usb5 bus xHCI Host Controller
/6 usb6 bus xHCI Host Controller
/7 usb7 bus xHCI Host Controller
/8 usb8 bus xHCI Host Controller
/9 mmc0 bus MMC Host
/a mmc1 bus MMC Host
/a/aaaa /dev/mmcblk1 disk 15GB SL16G
/a/aaaa/1 /dev/mmcblk1p1 volume 256MiB EXT4 volume
/a/aaaa/2 /dev/mmcblk1p2 volume 14GiB EXT4 volume
/b mmc2 bus MMC Host
/b/1 generic SDIO Device
/b/1/1 mmc2:0001:1 generic 43455
/b/1/2 mmc2:0001:2 generic 43455
/b/1/3 mmc2:0001:3 communication 43455
another similar device that booted into ubuntu shows this ( no 9 is wireless here)
/9 wlan0 network Wireless interface
–edit–
the entry for the wireless device was the /b/1/3 mmc2:0001:3 communication 43455
the build was missing module in modules/net/wireless/broadcom
https://forum.armbian.com/forum/188-rock-5b/
Here is kernel config:
In case some firmware is missing:
I see broadcom wireless is not added in the config, and the resulting setup does not contain brcmfmac.ko module.
CONFIG_BRCMFMAC is not set
Currently trying to build by adding that option.
I used armbians build mechanism
Selected option to customize config
Searched for CONFIG_BRCMFMAC and enabled it
It worked
I believe it should be added for the defaultmbuild
