Kernel version of debian release is too old to suport my application ,so I try armbian with radxa github public version.But it don't works well.top frequency maybe very low.and I can't read it:
pi@rockpi-s:/sys/devices/system/cpu/cpufreq$ ls
I capture some system boot log,wish someone can help me!
Lstrong textoading Environment from nowhere… OK
In: serial
Out: serial
Err: serial
Model: Radxa ROCK Pi S
rockchip_dnl_key_pressed read board id failed
Net: eth0: ethernet@ff4e0000
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
3185 bytes read in 3 ms (1 MiB/s)
Executing script at 00500000
Boot script loaded from mmc 1
225 bytes read in 3 ms (73.2 KiB/s)
11385968 bytes read in 482 ms (22.5 MiB/s)
30212608 bytes read in 1273 ms (22.6 MiB/s)
53606 bytes read in 8 ms (6.4 MiB/s)
Failed to load ‘/boot/dtb/rockchip/overlay/rk3308-fixup.scr’
Moving Image from 0x680000 to 0x800000, end=2570000
Loading init Ramdisk from Legacy Image at 04000000 …
Image Name: uInitrd
Image Type: AArch64 Linux RAMDisk Image (gzip compressed)
Data Size: 11385904 Bytes = 10.9 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum … OK
Flattened Device Tree blob at 02800000
Booting using the fdt blob at 0x2800000
Loading Ramdisk to 1d44f000, end 1df2ac30 … OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
Loading Device Tree to 000000001d3d9000, end 000000001d44efff … OK
Starting kernel …
Loading, please wait…
Starting version 247.3-7
Begin: Loading essential drivers … done.
Begin: Running /scripts/init-premount … done.
Begin: Mounting root file system … Begin: Running /scripts/local-top … done.
Begin: Running /scripts/local-premount … done.
Begin: Will now check root file system … fsck from util-linux 2.36.1
[/sbin/fsck.ext4 (1) – /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1
/dev/mmcblk0p1: clean, 36174/7651328 files, 779524/15282176 blocks
done.
done.
Begin: Running /scripts/local-bottom … done.
Begin: Running /scripts/init-bottom … done.
Welcome to Armbian 22.05.0-trunk Bullseye!
[ OK ] Created slice system-getty.slice.
[ OK ] Created slice system-modprobe.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice User and Session Slice.
[ OK ] Started Forward Password R…uests to Wall Directory Watch.
[ OK ] Set up automount Arbitrary…s File System Automount Point.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Paths.
[ OK ] Reached target Remote File Systems.
[ OK ] Reached target Slices.
[ OK ] Reached target Swap.
[ OK ] Reached target System Time Set.
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on fsck to fsckd communication Socket.
[ OK ] Listening on initctl Compatibility Named Pipe.
[ OK ] Listening on Journal Audit Socket.
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Control Socket.
[ OK ] Listening on udev Kernel Socket.
Mounting Huge Pages File System…
Mounting POSIX Message Queue File System…
Mounting Kernel Debug File System…
Mounting Kernel Trace File System…
Starting Restore / save the current clock…
Starting Set the console keyboard layout…
Starting Create list of st…odes for the current kernel…
Starting Load Kernel Module configfs…
Starting Load Kernel Module drm…
Starting Load Kernel Module fuse…
[ OK ] Started Nameserver information manager.
[ OK ] Reached target Network (Pre).
