Just dropped last night, it now supports the NVME, WiFi and both NICs, so if you’re keen to try trixie, here you go!
I can confirm that nvme and both NIC’s are working perfectly.
Thanks ![]()
Excuse me,
Can you please help me out, Im working with Cubie A5E and want to use RS485 CAN HAT (B) with it. Ive tried different OS options but nothing worked other than RadxaOS, also since it didnt have drivers for RS485 I went towayrds tina linux SDK where i configured one according to my needs(SPI and CAN on) but even that did not either flash properly or didnt boot on Cubie(only green light and no blinking blue light).
Does this also allow booting from NVME or is it just being able to use it as storage?
I flashed the image to NVME, but it didn’t boot, so I flashed it to the SD card too.
It then booted from the SD card, but used the NVME as the root directory /
hey dude same here no other os other than radxa os works same only green light
Yes. I have it booting from NVME. You may have to do some U-Boot tweaking - I have U-Boot loaded into the SPI, so theoretically I can boot from SD, NVME and USB.
