Release notes:
v21.02.1 (2021-02-03)
Finished projects
- [AR-235] - Implement Device Tree Editor
- [AR-476] - Add sound to Odroid N2
- [AR-485] - Improve multicore compilation
- [AR-487] - Rework download pages
- [AR-508] - Add Odroid HC4
- [AR-546] - Added Pine64 Pinecube
- [AR-566] - Add Nanopi R4S
- [AR-568] - Add Orangepizero 2 WIP target
- [AR-571] - Move Meson64 DEV to 5.10.y
- [AR-589] - Add ZShell via armbian-zsh package
- [AR-590] - ZRAM Enhancements - decouple swap config from tmp
Closed task
- [AR-163] - Systematically cleanup distribution defaults
- [AR-206] - Improve memory performance on Renegade (roc-rk3328-cc) in current
- [AR-399] - Improve Pinebook PRO support
- [AR-467] - Enable AUFS support back
- [AR-472] - Added support for Ubuntu 20.10 Groovy
- [AR-517] - Mark Bionic builds host as deprecated
- [AR-520] - Move Rock64 to CSC in build script
- [AR-525] - Bump Rockchip 32bit to 5.9.y
- [AR-526] - Move mvebu-dev kernel to 5.9+
- [AR-551] - Update fan configuration, enable network LED and enable UPS timer
- [AR-552] - Re-enable UHS SDR104 mode for Helios64 and roc-rk3399-pc
- [AR-553] - Update builder to retrieve web seeds from mirrors api
- [AR-554] - OdroidN2 Ethernet Failure Pt2
- [AR-556] - Adding vnstat and ZFS support to MOTD
- [AR-558] - Switch mvebu current to K5.9
- [AR-563] - Improve headers compilation
- [AR-576] - Enabled debug on RockpiS
- [AR-579] - Improve (oh-my)ZSH loading speed
- [AR-587] - Fix kernel switching for rk3399 family
- [AR-594] - Upgrade Meson64 u-boot to 2020.10
- [AR-598] - Switch rockchip64 u-boot to 2020.10
- [AR-601] - Move sunxi-current to 5.10.y
- [AR-603] - Enable SPI boot option for roc-rk3399-pc
- [AR-607] - Move Meson64 Current to 5.10.y
- [AR-609] - Move Mvebu Current to 5.10.y
- [AR-611] - Switch rockchip64-current to 5.10.y
- [AR-614] - Upgrade ZFS packages
- [AR-618] - Upgrade mvebu64 current to 5.10.y
- [AR-619] - Bump rockchip current to 5.10.y
- [AR-620] - Enable network link leds for NanoPi R4S by default
- [AR-622] - Enable DMC for Station-M1 in current and dev
- [AR-623] - Enable RTC (hym8563) for Station P1 in dev and current
- [AR-624] - Provide an option to skip autodetection at first login
- [AR-628] - Bump Meson64 u-boot to 2021.01
- [AR-630] - Bump Odroid XU4 DEV to 5.10.y
Solved bugs
- [AR-365] - 4k not detected properly on Amlogic, Rockchip devices
- [AR-440] - Errors shown at 1st login under certain conditions
- [AR-512] - Fix Ethernet for Opi3 and other devices with phymode for kernel 5.10
- [AR-514] - Download and verify not fully reliable
- [AR-547] - First login: adding a non-existing keyboard variant
- [AR-548] - mvebu DFS seems to cause system hang under high I/O
- [AR-557] - GCC compatibility issues
- [AR-559] - First login script - not all locales have UTF8 encoding
- [AR-565] - SATA on HC4 is not recognized
- [AR-570] - Improper order in getty override.conf
- [AR-584] - Nanopi M4V2 hangs on bluetooth loading
- [AR-595] - Rockpi 4B 1GB not booting
- [AR-605] - Booting troubles on Odroid C4 / HC4
- [AR-606] - Force boot script update throws out some error
- [AR-608] - Broken building out-of-tree modules
- [AR-610] - Nanopi Neo2 black sometimes nic doesn't init
- [AR-616] - Ubuntu Bionic ZSH / BASH changing issue
- [AR-617] - Locales detection doesn't work properly in some cases
- [AR-627] - Ubuntu update is overwriting our welcome screen
- [AR-629] - Odroid HC4 SATA failure
- [AR-631] - Orangepi Zero2 broken network
- [AR-632] - Desktop fails to load at second run
