Anybody know anything about the ADC?
Anybody have any ideas how to use the ADC? Information seems to be minimal to non-existant, not just for the rockpi4, but for the rk3399 in general. I’ve hooked a potentiometer up to the ADC GPIO pin and can see some kind of response from
cat /sys/bus/iio/devices/iio:device0/in_voltage*
so I know there is something resembling a live driver loaded in the system. I get nothing that makes any sense though. Some of the channels change sort of linearly with the potentiometer voltage, but I can see no overall explanation for the results.
Anybody know anything here? I’m not even certain what the voltage range is, or if a device tree overlay is necessary to properly initialize the device. Thanks.
hi,@dbqpdb
you can install libmraa
https://wiki.radxa.com/Rockpi4/dev/libmraa
or you can compile it by yourself
https://github.com/intel-iot-devkit/mraa
Great, seems to work just fine, thank you kindly. I think the thing that was not clear to me is that the ADC input voltage range is 0-1.8v. For for future reference for anybody reading this, the input voltage seem to be directly mirrored into /sys/bus/iio/devices/iio:device0/in_voltage0_raw upto 1.8v. And I’m not sure if this is supported, or likely going to burn something out, but voltages higher than 1.8v get read linearly into /sys/bus/iio/devices/iio:device0/in_voltage2_raw. The other iio voltages change with input to the ADC pin, but now with any logic that I can see.
