Android perfomance mode
Is there any to have some performance mode, in android config. I have some apps which doesn’t use full performance (800, 1200 Mhz) and cause sound delay. I compare some console emulators, moonlight (gforce game stream) and shadow PC (cloud gaming platform). And moonlight which force 1400Mhz have much better sound sync. I saw that by rooting android we can change min / max proce frequency, is there simpler way.
Apart from that, I’am a quite amazed on how this SPC perform on android, I was almost making gamecube emulator (dolphin) working.
Thanks,
Have you tried
https://play.google.com/store/apps/details?id=com.smartprojects.CPUControlLite or
https://play.google.com/store/apps/details?id=com.dsmartapps.root.kerneltweaker&hl=en
to try to change the CPU frequency?
Must be rooted with Magisk for most of these apps to work.
thanks @mo123,
Not yet, I thought a non root solution existed, I’m using your distro by the way (which is awesome), I saw somewhere you made a quick tuto on how to root it. I’ll try this solution.
I root it and use the kernel tweakwer app, is that normal that all CPUs are capped to 1400 Mhz ?
There are 4 little cores running at 1.4Ghz and the 2 Big cores running at 1.6/1.8Ghz.
So maybe these apps only detect the little cores and not the 2 big ones?
Then perhaps other apps might work better.
I found some CPUs monitoring apps, and it seems the 2 1,8 Cpus a used for background tasks, maybe there is way to define how cpus are prioritized. kernel tools dosn’t detect 2 fast CPUs.
I found some app better handling CPU settings, it doesn’t really resolved my sound delay issue, it’s more because of the apps (Shadow PC). Thanks for your help @mo123.
