Android image building problem
I am building the image for Radxa Zero according to the guide,something went wrong:
make: Entering directory ‘/home/radxa/zero-android9/out/target/product/faraday/obj/KERNEL_OBJ’
WARNING: Symbol version dump ./Module.symvers
is missing; modules will have no dependencies and modversions.
LD /home/radxa/zero-android9/out/target/product/faraday/obj/bifrost/kernel/drivers/gpu/arm/midgard/built-in.o
CC [M] /home/radxa/zero-android9/out/target/product/faraday/obj/bifrost/kernel/drivers/gpu/arm/midgard/mali_kbase_device.o
In file included from /home/radxa/zero-android9/common/include/linux/ktime.h:25:0,
from /home/radxa/zero-android9/common/include/linux/rcupdate.h:47,
from /home/radxa/zero-android9/common/include/linux/rculist.h:10,
from /home/radxa/zero-android9/common/include/linux/dcache.h:6,
from /home/radxa/zero-android9/common/include/linux/fs.h:7,
from /home/radxa/zero-android9/common/include/linux/debugfs.h:18,
from /home/radxa/zero-android9/out/target/product/faraday/obj/bifrost/kernel/drivers/gpu/arm/midgard/mali_kbase_device.c:29:
/home/radxa/zero-android9/common/include/linux/jiffies.h:11:33: fatal error: generated/timeconst.h: No such file or directory
#include <generated/timeconst.h>
compilation terminated.
make[3]: *** [/home/radxa/zero-android9/common/scripts/Makefile.build:335: /home/radxa/zero-android9/out/target/product/faraday/obj/bifrost/kernel/drivers/gpu/arm/midgard/mali_kbase_device.o] Error 1
make[2]: *** [/home/radxa/zero-android9/common/Makefile:1623: module/home/radxa/zero-android9/out/target/product/faraday/obj/bifrost/kernel/drivers/gpu/arm/midgard] Error 2
make[1]: *** [Makefile:152: sub-make] Error 2
make: *** [Makefile:24: __sub-make] Error 2
make: Leaving directory ‘/home/radxa/zero-android9/out/target/product/faraday/obj/KERNEL_OBJ’
[ 0% 19/60825] //external/protobuf:ap…piler/cpp/cpp_message.cc [linux_glibc]
ninja: build stopped: subcommand failed.
15:41:17 ninja failed with: exit status 1
failed to build some targets (01:33 (mm:ss))
How do I fix this?
