Building Android for Zero, based on doc here.
Installed fresh Ubuntu 16 on laptop:
$ dmesg
[ 0.000000] microcode: microcode updated early to revision 0x28, date = 2019-11-12
[ 0.000000] Linux version 4.15.0-142-generic (buildd@lgw01-amd64-039) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.12)) #146~16.04.1-Ubuntu SMP Tue Apr 13 09:27:15 UTC 2021 (Ubuntu 4.15.0-142.146~16.04.1-generic 4.15.18)
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-142-generic root=UUID=712d11a4-5379-45c5-9559-98079be9f1d0 ro quiet splash vt.handoff=7
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] Centaur CentaurHauls
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using ‘standard’ format.
[ 0.000000] e820: BIOS-provided physical RAM map:
Building with command:
./device/amlogic/common/quick_compile.sh 14 1
Error:
/home/zero/common/scripts/gcc-version.sh: line 25: /opt/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: No such file or directory
/home/zero/common/scripts/gcc-version.sh: line 26: /opt/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: No such file or directory
make[2]: /opt/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: Command not found
/bin/sh: 1: /opt/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-gcc: not found
make[3]: *** [/home/zero/out/target/product/faraday/obj/optee_modules/tee_shm.o] Error 127
make[3]: *** Waiting for unfinished jobs…
make[3]: *** [/home/zero/out/target/product/faraday/obj/optee_modules/tee_core.o] Error 127
make[2]: *** [module/home/zero/out/target/product/faraday/obj/optee_modules] Error 2
make[1]: *** [sub-make] Error 2
make: *** [__sub-make] Error 2
