We have a Rock 5B which will be running a specialized app on a small touch screen which will be in portrait orientation. I can’t get the display to rotate to portrait even after setting the auto rotate to off and using
OK while writing this up, I decided to test on the previous Rock5B-Android12-rkr12-Tablet-20221129-gpt image, and using the above adb command DOES work. So something is broken in the most recent 20230315 release.
This is a problem because I am currently working on a custom Android image I built by modifying a few parameters in the Radxa Android source code, and I must be using the most up to date code because my custom image has the same rotation issue.
So does anyone know:
A) How I could check out the code for the 20221129 release and make my custom image from that point
B) How I could fix this by fixing/modifying the source code
C) Or how I could fix it some other way?
@Sandor- good luck. Hopefully you’ll have better experience than I did. Sandisk sd cards wouldn’t work (not the 5 ones I tried) a few android 12 images I found on the official Radxa wiki couldn’t be flashed using Etcher so I finally got one to work . No play store and I had to disable notifications so I didn’t get a device not certified message every 10 seconds geez! Again good luck
It’s frustrating when even adb commands fail to yield the desired results. Have you considered reaching out to the manufacturer for further assistance? Sometimes they can provide valuable insights or even release patches to address such issues. Another avenue to explore could be online forums or communities where fellow users might have encountered and resolved similar challenges.
