Android 11 wlan is not working
A6S AP6275 wifi/BT module.
By Rock3A, debian package works well with Wifi, BT.
Also BT works well with android11.
When I tries to set Android - settings - Network & internet - Wi-Fi - Off to On - it "off"ed immediately.
At the console, I call below command.
console:/ $ svc wifi enable
console:/ $ dumpsys wifi | grep “Wi-Fi is”
Wi-Fi is disabled
console:/ $ settings get global wifi_on
1
Below is booting sequence for wifi.
Any advice would be highly appreciated.
[ 2.804596] [BT_RFKILL]: Enter rfkill_rk_init
[ 2.804604] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 2.805046] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 2.805079] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6256
[ 2.805090] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 2.805098] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 2.805126] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 125, flags = 0.
[ 2.805499] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 2.805512] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 2.805521] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 2.806012] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 77.
[ 2.806038] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 138.
[ 2.806049] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 141.
[ 2.806059] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 140.
[ 2.806106] [BT_RFKILL]: Request irq for bt wakeup host
[ 2.806170] [BT_RFKILL]: ** disable irq
[ 2.806271] [BT_RFKILL]: bt_default device registered.
[ 7.458273] ======== dhd_wlan_init_plat_data ========
[ 7.458280] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 7.458341] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=117, oob_irq_flags=0x414
[ 7.458354] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 7.458360] dhd_wifi_platform_load: Enter
[ 7.458366] Power-up adapter ‘DHD generic adapter’
[ 7.458785] wifi_platform_set_power = 1
[ 7.458807] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 7.458814] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 7.458820] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 7.458826] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 7.770445] wifi_platform_bus_enumerate device present 1
[ 7.864611] init: starting service ‘wificond’…
[ 9.885957] wifi_platform_set_power = 0
[ 9.885982] ======== PULL WL_REG_ON(-1) LOW! ========
[ 9.885989] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 9.886003] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.886008] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 9.886014] wifi_platform_bus_enumerate device present 0
[ 9.886019] ======== Card detection to remove SDIO card! ========
[ 9.886024] mmc3:mmc host rescan start!
[ 9.886091] wifi_platform_set_power = 1
[ 9.886097] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 9.886101] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 9.886106] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 9.886111] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 10.193757] wifi_platform_bus_enumerate device present 1
[ 12.232725] ======== PULL WL_REG_ON(-1) LOW! ========
[ 12.232731] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 12.232744] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 12.232749] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 12.232755] wifi_platform_bus_enumerate device present 0
[ 12.232780] wifi_platform_bus_enumerate device present 0
[ 15.790719] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 15.794656] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 17.428344] type=1400 audit(1659221215.263:37): avc: denied { read } for comm=“Binder:434_3” name=“state” dev=“sysfs” ino=15565 scontext=u:r:system_server:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
[ 18.416468] init: processing action (sys.sysctl.tcp_def_init_rwnd=*) from (/system/etc/init/hw/init.rc:994)
[ 18.798696] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 19.239436] type=1107 audit(1659221217.070:40): uid=0 auid=4294967295 ses=4294967295 subj=u:r:init:s0 msg=‘avc: denied { set } for property=sys.gmali.version pid=585 uid=10113 gid=10113 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:system_prop:s0 tclass=property_service permissive=1’
[ 19.794843] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 20.795601] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 21.796366] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 22.797467] init: Control message: Processed ctl.interface_start for ‘[email protected]::IWifi/default’ from pid: 144 (/system/bin/hwservicemanager)
[ 23.201243] init: Service ‘bootanim’ (pid 177) exited with status 0 oneshot service took 17.961000 seconds in background
well nothing is changed lately for android 11 i can see
and litle sparse info linux works android not ?
wich images used ?
Below debian Package works well with wlan.
rock-3a-debian-buster-xfce4-arm64-20220701-0158-gpt.img
I built and test Android image with default option, rk356x_rock_3a_r_20220729.1812_gpt.img
exactly same build procedure like below.
https://wiki.radxa.com/Rock3/Android11
also I did test with official image “rock3a-android11-20220408_1204-gpt.img”
but result was same.
adb shell “svc wifi enable”
adb shell am start -n com.android.settings/.wifi.WifiStatusTest
Starting: Intent { cmp=com.android.settings/.wifi.WifiStatusTest }
adb shell dumpsys wifi | grep “Wi-Fi is”
Wi-Fi is disabled
adb shell settings get global wifi_on
1
I did test A2 A6S module.
About A2
while connecting Ethernet wlan is not working.
when disconnect Ethernet , then wlan is connected.
But A6S is always Wi-Fi Off.
Think you didnt adjust the dts for the wifi it is default ap6256 and doesnt sound as ap6275
and some info from not official site
just look at the wifi6 patches they added to the android 11 sdk
