if i use the mixer app i see an audio level on the outout device (rockchip,es8316-codec) but when i connect my ear plugs i hear nothing.
The ear plug is woking on my laptop.
Have anyone this problem too or a solution for this?
BR a.kratzer
BR a.kratzer
What OS are you running? Check out my post “Building Debian ARM64” if that’s what you are using.
Yes i run the debian with the radxa apt repo (ARM64) With the std kernel from the apt repo.
i have ordered a secound rock pi 4 to verify if it is a HW failure
Which exactly the kernel version is? uname -r
4.4.154-73-rockchip-00007-g155a65a
In my build, it was the dtb not the kernel caused the problem. After I copied rockpi4-linux.dtb from the armhf build (which you can download) I got audio.
i have test it and it works ;o)
i think the rockpi4-linux.dtb from the 4.4.154-73-rockchip-00007-g155a65a is broken/wrong
thx for your support
Yet. I am working on it.
Hi, to fix the problem with analog audio es8316, the new kernel packages
linux-4.4-lastest
are updated.
Due to the space of boot partition, you’d better not leave more than two kernel packages.
To see the installed kernel packages, check file /boot/extlinux/extlinux.conf, which includes one line, like this.
label kernel-4.4.154-73-rockchip-00007-g155a65a (format: label INSTALLED_KERNEL_VERSION)
To find the packages corresponding to the installed kernel version, check https://wiki.radxa.com/Rockpi4/radxa-apt. Then use apt-get remove
to remove them.
Example:
If you fail to finish one of steps, just try reboot. And do not use apt-get upgrade
or apt-get dist-upgrade
Firstly, remove packages to free up space.
sudo rm -rf /var/cache/apt/archives
sudo apt-get remove linux-4.4-lastest
sudo apt-get remove linux-image-4.4.154-73-rockchip-00007-g155a65a (remove all except one)
Secondly, reboot rockpi4.
Thirdly, install packages
sudo apt-get update
sudo apt-get install linux-4.4-lastest
