The project to use with radxa zero will use another i2c device, but we connected Arduino to test i2c.
As you can see, in radxa zero, we also modified the /boot/uEnv.txt file to use gpio 14 and 15 as i2c. (Photo 1).
And if you look at the second attached picture, you can see how I connected with Arduino. (Photo 2)
However, if you check through the i2cdetect-y3 command, you can see that there is an unknown i2c device called 0x22, but I have never given this address.
And Arduino’s I2C address is not confirmed. (Photo 3)
I don’t know what device 0x22 is, and am I using I2C normally?
