AIC8800D80 Wi-Fi 6 Driver Notes for Radxa Cubie A5E (Linux 7.1 / Buildroot)
Below are notes on bringing up the AIC8800D80 SDIO Wi-Fi 6 chipset on the Radxa Cubie A5E (Allwinner T527) running Linux 7.1.
Instead of the vendor SDK driver, we used the wireless-next RFC v2 patch series (aic8800_bsp.ko + aic8800_fdrv.ko).
Key Technical Changes
  1. Firmware Path: Place firmware files (fw_patch_table_8800d80_u02.bin, fw_adid_8800d80_u02.bin, fw_patch_8800d80_u02.bin, fmacfw_8800d80_u02.bin) in /lib/firmware/aic8800/.
  2. Stack Protector Fix: Fixed a 4-byte buffer overflow in aicbt_patch_info_unpack() (aic_bsp_driver.c) by culling memcpy length to struct aicbt_patch_info_t bounds.
  3. SDIO Bus Sharing: Build with CONFIG_AIC8800_FDRV_NO_REG_SDIO=y so aic8800_fdrv.ko connects to the active aic8800_bsp.ko bus without SDIO driver registration collisions.
  4. Kernel 7.1 APIs: Updated netif_rx, cfg80211_probe_status, and remain_on_channel signatures.
Status
  • Hardware init and firmware load complete in <300ms (rd_version_val=06090101).
  • Interface wlan0 registers, acquires DHCP, and passes traffic normally.
The driver source tree and Buildroot package are available here: https://github.com/tcmichals/cubie-a5e (aic8800-upstream/)
Could you tell me if all of this is integrated into the scripts from your repository? Are you planning on publishing ready-made images? From what I’ve seen, you claim that the LAN, GPU, WiFi, and everything else is almost fully functional for the A5E. Can you confirm this?
Here is where I’m at:
  • Ethernet works
  • WiFi works (I’m updating the driver to be universal SDIO and USB) I’ve been struggling with the A7A Bridge chip. But I think I’m close. The end goal, RFC V3 (mainline linux), or GitHub - ronnyf/AIC8800-Linux-Driver · GitHub
  • remoteproc, has been sent to sunxi mainlining, need to submit another rev to sunxi mainlining.
  • Camera: Still work in progress, have a list I’m working on. Have a todo list, to flush out drivers etc.
  • NPU. (This should work, I have not tested it)
    The goal is to push a lot of this to mainline Linux and then all the distro will have it.
    A lot of rework has been done over the past few days to help get the above working.
    Your question: Will I have a disk image? No. Right now, you can follow the instructions using Ubuntu Linux x86 distro and compile.
    I’m also working on A7A, using updated re-written/ported drivers that are ready to submit.
Yes, you can compile the repo, there is instructions. This is a buildroot out of tree.
