Just a warning:
I’m using mainline Fedora 44 on Q6A.
Today I’ve updated to Linux 7.1.3
AIC8800-USB module failed to build.
If you need Wi-Fi/BT, I recommend staying on Linux 7.0.14
Still wondering when Q6A will get full mainline support.
Just a warning:
Hi katsu,
This is a known breakage, not something you did wrong — the out-of-tree aic8800 fullmac driver doesn’t build on Linux 7.1.x. Mainline 7.1 made a few API changes the driver hadn’t caught up with:
cfg80211_ops key/station callbacks (add_key, get_key, del_key, add_station, del_station, change_station, get_station, dump_station, set_default_mgmt_key) switched from struct net_device * to struct wireless_dev *, and get_tx_power gained new radio_idx/link_id params;in_irq() was removed (now in_hardirq());ieee80211_mgmt.u.action became anonymous, which breaks the TDLS discover-response builder.I hit the same thing bringing the RK3576 up on a mainline 7.1.3 kernel and wrote a compat patch for it (all gated behind LINUX_VERSION_CODE >= 7.0.0, so it still builds on older kernels):
https://github.com/gahingwoo/kiln/blob/main/aic8800-patches/0001-aic8800-cfg80211-7.1-net_device-to-wireless_dev.patch
Two caveats, in the spirit of not overpromising:
/lib/firmware/ for your chip variant. If your Q6A’s aic8800 variant differs from the ROCK 4D’s, double-check the firmware side.If it builds and Wi-Fi/BT come back for you, great — and if it doesn’t, let me know what fails and I’ll take a look.
I see a fix in the changelog, have you tested it?
I suppose this changelog involves radxa-build images.
I’ve decided to give up with mainline distros and moved to radxa-dragon-midstream variant of Radxa OS (26.04).
It seems like devs fixed all the annoying things like sound, Gnome Extensions, etc.
