I want to use this SSD and, oh wonder, it doesn’t work. I tried:
- Kernelupdate
- lsblk
- lspci
Nothing…
Kernel is 4.4.154-83. Does anybody know about this?
sudo dmesg | grep -E “pcie”
says Nothing… Maybe is PCIe not working?
Nothing…
Solution:
Turn off, wait, disconnect power
-> Turn on
Actually don’t use ssh use the console not saying it will work but dmesg | grep pci will show something.
sudo apt-get install pciutils as lspci should detect something, might be you need to do the pcie gen2 edit but wondering if you might be like me and its just pure chance on each boot due to some sort of timing.
I just had it work 3 times on a trot and now its gone again by just power on and then shutdown.
Is yours constantly intermittent if it boots with pcie? Worked 4 times as just tried again but its pure random with absolutely no change but shutdown and boot.
when it works sudo apt-get install iozone3
Auto Mode
Include fsync in write timing
O_DIRECT feature enabled
File size set to 81920 kB
Record Size 4 kB
Command line used: iozone -a -e -I -i 0 -i 1 -i 2 -s 80M -r 4k
Output is in kBytes/sec
random random bkwd record stride
kB reclen write rewrite read reread read write read rewrite read fwrite frewrite fread freread
81920 4 28607 34861 39915 40103 16139 30980
Try to update to the latest u-boot and check if it works.
sudo apt-get install rockpi4b-rk-u-boot-latest
sudo /usr/local/sbin/rockpi4b_upgrade_bootloader.sh
It works at the Moment. Thanks for all the help
