I have a CM3i with a CM3i IO board, I flashed Debian on it.
I need to test PWM on a pin. Pl_nLED_Activity (GPIO4 C6, gpiochip4 line 22) isn’t connected to the power button, I can use it as simple IO pin with gpioset. According to the wiki, I need to use python and enable the overlay.
With rsetup I’m supposed to use the overlay “rk3568-pwm13-m1.dts”. I loaded this as an external file. The status in gpioinfo doesn’t change. Running a python script, this errors with:
File “/usr/lib/python3/dist-packages/periphery/pwm.py”, line 60, in _open raise LookupError(“Opening PWM: PWM chip {} not found.”.format(chip))
LookupError: Opening PWM: PWM chip 4 not found.
Looking in the pwm.py script, it tries to access /sys/class/pwm/pwmchip/pwmchip4, but the address doesn’t exist. That folder only has pwmchip8 and pwmchip13 as subdirectories. Am I trying to access PWM the wrong way, or doing something unsupported?
cat /sys/kernel/debug/pinctrl/pinctrl-rockchip-pinctrl/pinmux-pins | grep -i pwm
pin 105 (gpio3-9): fe6f0000.pwm (GPIO UNCLAIMED) function pwm8 group pwm8m0-pins
the pinmux file says the PWM to the fan header is claimed, while rsetup was NOT configured for it.
