I found “1x USB 3 HOST port, 1x USB3 OTG port” in the document. Which USB3 port supports OTG?
The USB type C support OTG.
Neither USB-A supports OTG?
No. All the USB A port of ROCK 5B can not support OTG. There is one USB 3.0 OTG bus from the SoC on the upper USB 3.0 double layer A ports, but the ROCK 5B design can not support it because of the power implementation limitation.
Hi, does the USB C OTG support true 3.0 speed (ie 5 gbps)? I plan to use it for storage so this is important.
Also how about the USB A OTG port on the 5A and 5C? Do they support USB 3.0 in OTG mode?
Thanks
Michael
It does. Tested on Rock 5 ITX since I found no way to test it on Rock 5B due to USB-C also being used for powering the board and me lacking an USB-C Dock…
