I wanted to connect to Rock 3c, Debian Bullseye from a Windows 10 PC using Windows 10 standard remote desktop software, so I executed the following command.
1) Tightvncserver installation command: “sudo apt install tinyvncserver”
2) xrdp installation command: “sudo apt install xrdp”
After running each, I entered the Rock 3c's IP address from my Windows PC to establish a connection, but the Rock 3c's desktop does not appear even after entering the ID and password.
However, you can connect using another character terminal software (CUI).
You can connect to Raspberry-pi (stretch) using remote desktop on Windows-PC.
Thank you for your advice.
I followed the remote login procedure, but unfortunately I cannot log in using the GUI from a Windows-10 PC.
I am attaching a copy of some of the screens below.
— Start ----------------------------------------------------------------------------
rock@rock-3c:~$ vncserver
New Xtigervnc server ‘rock-3c:1 (rock)’ on port 5901 for display :1.
Use xtigervncviewer -SecurityTypes VncAuth -passwd /home/rock/.vnc/passwd :1 to connect to the VNC server.
rock@rock-3c:~$ vncserver -kill :1
Killing Xtigervnc process ID 1063… success!
rock@rock-3c:~$ vncserver -localhost no
Use xtigervncviewer -SecurityTypes VncAuth,TLSVnc -passwd /home/rock/.vnc/passwd rock-3c:1 to connect to the VNC server.
Next, I tried connecting to Rock-3c with “RealVNC Viewer 7.8.0 (r51458) x64 (Nov 2 2023 16:07:13)” on Windows 10.
At the same time, I monitored the protocol using Windows 10’s “WireShark”, but data was sent to Rock-3c’s 5901 port using UDP, but Rock-3c disconnected at RST-ack.
Next, attach the “~/.vnc/rock-3c:5901.log” file.
An error or warning has occurred.
I’m thinking that there’s probably something wrong with the settings.
Fri Nov 17 10:49:11 2023
vncext: VNC extension running!
vncext: Listening for VNC connections on local interface(s), port 5901
vncext: created VNC server for screen 0
3NI3X0 New Xtigervnc server ‘rock-3c:1 (rock)’ on port 5901 for display :1.
3NI3X0 Use xtigervncviewer -SecurityTypes VncAuth -passwd /home/rock/.vnc/passwd :1 to connect to the VNC server.
/usr/bin/startxfce4: X server already running on display :1
(xfce4-session:1053): dbind-WARNING **: 10:49:12.641: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
/usr/bin/iceauth: creating new authority file /run/user/1001/ICEauthority
xfce4-session: No GPG agent found
dbus-update-activation-environment: warning: error sending to systemd: org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
(xfwm4:1126): dbind-WARNING **: 10:49:13.385: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfwm4:1126): xfwm4-WARNING **: 10:49:14.639: Unsupported GL renderer (llvmpipe (LLVM 11.0.1, 128 bits)).
(xfsettingsd:1141): dbind-WARNING **: 10:49:14.826: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfce4-panel:1144): dbind-WARNING **: 10:49:15.316: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(Thunar:1148): dbind-WARNING **: 10:49:15.547: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfdesktop:1153): dbind-WARNING **: 10:49:15.844: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfce4-session:1053): xfce4-session-WARNING **: 10:49:16.416: Unable to launch “light-locker” (specified by autostart/light-locker.desktop): Failed to execute child process “light-locker” (No such file or directory)
unable to find device goodix-ts
unable to find device fts_ts
(xfce4-power-manager:1158): dbind-WARNING **: 10:49:16.659: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
** (xfce4-power-manager:1158): WARNING **: 10:49:16.690: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name ‘org.freedesktop.PowerManagement’: no such name
** (xfce4-power-manager:1158): WARNING **: 10:49:16.692: Failed to get name owner: GDBus.Error:org.freedesktop.DBus.Error.NameHasNoOwner: Could not get owner of name ‘org.xfce.PowerManager’: no such name
Xlib: extension “DPMS” missing on display “:1.0”.
(xfce4-power-manager:1158): xfce4-power-manager-WARNING **: 10:49:16.787: Monitor is not DPMS capable
Failure: Module initialization failure
(xfce4-notifyd:1165): dbind-WARNING **: 10:49:16.906: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(nm-applet:1156): dbind-WARNING **: 10:49:16.960: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(polkit-gnome-authentication-agent-1:1174): dbind-WARNING **: 10:49:17.040: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfce4-screensaver:1160): dbind-WARNING **: 10:49:17.148: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfsettingsd:1186): dbind-WARNING **: 10:49:17.300: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
** (xiccd:1163): WARNING **: 10:49:17.513: EDID is empty
(xfce4-power-manager:1158): GLib-GObject-WARNING **: 10:49:17.522: …/…/…/gobject/gsignal.c:2614: signal ‘Changed’ is invalid for instance ‘0xaaaadc93a140’ of type ‘GDBusProxy’
(polkit-gnome-authentication-agent-1:1174): polkit-gnome-1-WARNING **: 10:49:18.218: No icon for themed icon with name ‘application-vnd.iccprofile’
(polkit-gnome-authentication-agent-1:1174): polkit-gnome-1-WARNING **: 10:49:18.253: Couldn’t open user icon: Failed to open file “/home/radxa/.face”: No such file or directory
(polkit-gnome-authentication-agent-1:1174): polkit-gnome-1-WARNING **: 10:49:18.279: Couldn’t open user icon: Failed to open file “/home/rock/.face”: No such file or directory
(xfce4-power-manager:1158): xfce4-power-manager-WARNING **: 10:49:18.309: could not map keysym 1008ffa8 to keycode
(wrapper-2.0:1228): dbind-WARNING **: 10:49:18.342: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfce4-power-manager:1158): xfce4-power-manager-WARNING **: 10:49:18.413: Unable to inhibit systemd sleep: GDBus.Error:org.freedesktop.DBus.Error.AccessDenied: Permission denied
** (xfce4-power-manager:1158): WARNING **: 10:49:18.414: No outputs have backlight property
** (xfce4-screensaver:1160): WARNING **: 10:49:18.437: Screensavers already running in this session
(xfce4-power-manager:1158): xfce4-power-manager-WARNING **: 10:49:18.463: Failed to get keyboard max brightness level : GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.UPower.KbdBacklight” on object at path /org/freedesktop/UPower/KbdBacklight
(wrapper-2.0:1224): dbind-WARNING **: 10:49:18.559: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(wrapper-2.0:1230): dbind-WARNING **: 10:49:18.567: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(blueman-applet:1166): dbind-WARNING **: 10:49:18.979: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(wrapper-2.0:1310): dbind-WARNING **: 10:49:19.383: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
(xfce4-panel:1144): garcon-CRITICAL **: 10:49:19.867: garcon_gtk_menu_get_desktop_actions_menu: assertion ‘actions != NULL’ failed
blueman-applet 10.49.20 WARNING PluginManager:148 __load_plugin: Not loading PPPSupport because its conflict has higher priority
(xfce4-panel:1144): garcon-CRITICAL **: 10:49:20.067: garcon_gtk_menu_get_desktop_actions_menu: assertion ‘actions != NULL’ failed
(xfce4-panel:1144): garcon-CRITICAL **: 10:49:20.304: garcon_gtk_menu_get_desktop_actions_menu: assertion ‘actions != NULL’ failed
(xfce4-panel:1144): garcon-CRITICAL **: 10:49:20.542: garcon_gtk_menu_get_desktop_actions_menu: assertion ‘actions != NULL’ failed
(blueman-tray:1436): dbind-WARNING **: 10:49:21.035: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
blueman-applet 10.49.21 WARNING PluginManager:148 __load_plugin: Not loading DhcpClient because its conflict has higher priority
(wrapper-2.0:1230): GLib-GIO-CRITICAL **: 10:49:22.198: g_file_new_for_path: assertion ‘path != NULL’ failed
(wrapper-2.0:1230): GLib-GIO-CRITICAL **: 10:49:22.199: g_file_monitor_file: assertion ‘G_IS_FILE (file)’ failed
(wrapper-2.0:1230): GLib-GObject-WARNING **: 10:49:22.199: invalid (NULL) pointer instance
(wrapper-2.0:1230): GLib-GObject-CRITICAL **: 10:49:22.202: g_signal_connect_data: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
(wrapper-2.0:1230): Gtk-WARNING **: 10:49:22.202: Attempting to add a widget with type GtkToggleButton to a container of type XfcePanelPlugin, but the widget is already inside a container of type XfcePanelPlugin, please remove the widget from its existing container first.
(wrapper-2.0:1230): Gtk-WARNING **: 10:49:23.136: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button, owner GtkToggleButton)
(wrapper-2.0:1228): Gtk-WARNING **: 10:49:23.305: Negative content width -3 (allocation 1, extents 2x2) while allocating gadget (node button, owner PulseaudioButton)
(blueman-tray:1498): dbind-WARNING **: 10:49:23.819: AT-SPI: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
** (xiccd:1163): CRITICAL **: 10:49:42.539: failed to create colord device: Timeout was reached
** (xiccd:1163): CRITICAL **: 10:49:42.691: unable to connect to profile: Failed to connect to missing profile /org/freedesktop/ColorManager/profiles/icc_28a4727fd7bb0fca52bc3be3b26cf74d
** (xiccd:1163): CRITICAL **: 10:49:42.692: unable to connect to profile: Failed to connect to missing profile /org/freedesktop/ColorManager/profiles/icc_0f1fca9f8054c968960047329afcb4ab
** (xiccd:1163): CRITICAL **: 10:49:42.692: unable to connect to profile: Failed to connect to missing profile /org/freedesktop/ColorManager/profiles/icc_8e1a06e8463bb6c4652d30efa89661e4
My alternative to TigerVNC is x11vnc. It is useful if you need to see existing physical display (e.g. for headless login without keyboard) or just use it without physical display. Though, the output of x11vnc is slow (probably due to my poor WiFi connection to Radxa Zero 3W).
