I have the A8 wireless module from radxa but in their documentation for setting up the x2l, there is only documentation for the windows drivers. How can I get this set up with Linux?
Hi Sockpastarock,
I would recommend using the latest Kubuntu image, as it utilizes a newer kernel that supports the A8 module.
refer: https://cdimage.ubuntu.com/kubuntu/releases/24.04/beta/
If you are unwilling to use it, you may need to recompile your current Linux kernel, which is a rather tedious task.
Anyway, this document may be helpful to you as well, https://github.com/HRex39/rtl8852be
